82 Ramcharger wont run hot - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2011, 02:27 PM   #1
Jleach0696
Jleach0696's Avatar
Default 82 Ramcharger wont run hot
starts great cold get it up to temp runs fine shut it off and you have to floor it to get it to start then it wont stay running and sputters out
Jleach0696 is offline   Reply With Quote
Old June 9th, 2011, 03:16 PM   #2
GMKLR50
Broke wheeler
GMKLR50's Avatar
try a new cap and rotor, they seem to show themselves after driving rain and once the engine gets warm. Because of there location just under the hood seam water leaks on them and causes the cap to crack, I have had a few older dodge pick up and that happened ofter, i just always kept an exta set in the truck.
GMKLR50 is offline   Reply With Quote
Old June 9th, 2011, 08:27 PM   #3
Flat_Black
The Dodge Guy
Flat_Black's Avatar
sounds like the control module or ballist resistor
Old June 9th, 2011, 09:04 PM   #4
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
i agree with flat black. pull ecu and look at back if it is bulged out or discolored it prob needs to be replaced, same goes for voltage regulator.
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old June 10th, 2011, 01:44 AM   #5
Jleach0696
Jleach0696's Avatar
ignition control module?
Old June 10th, 2011, 08:07 AM   #6
Flat_Black
The Dodge Guy
Flat_Black's Avatar
yes
Old June 10th, 2011, 08:38 AM   #7
rottinjonny
Check the needle and seat in the carb?
rottinjonny is offline   Reply With Quote
Old June 10th, 2011, 06:12 PM   #8
Jleach0696
Jleach0696's Avatar
with the cold er weather it did not do it today starts and runs fine after its warm
Old June 13th, 2011, 08:19 AM   #9
GMKLR50
Broke wheeler
GMKLR50's Avatar
I agree with them too, as they could also be right. I have had problem with those as well, but its the temp of the day that has me leaning towards the cap and rotor, hot or humid days is when i saw the cap and rotor problem usually show just after or when it was raining. I would check all, none of these fixes are really that expensive.
Old June 13th, 2011, 08:34 AM   #10
87mopar
Web Wheeler :(
87mopar's Avatar
I had a 87 ramcharger, I had the same issue. I put on a spare coil and cap and rotor, problem fixed
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old June 18th, 2011, 01:43 PM   #11
Jleach0696
Jleach0696's Avatar
was the ballast resistor. should the new resistor be hot to the touch after running
Old July 6th, 2011, 09:24 PM   #12
SizeMatters
Sketchy, Son....
SizeMatters's Avatar
The longer you have to crank the motor, the hotter they get. The guys on moparchat say they tend to get warm. But if they are hottt, then theres a wiring issue.
SizeMatters is offline   Reply With Quote
Old July 11th, 2011, 11:53 AM   #13
Jleach0696
Jleach0696's Avatar
well it fires right up but the resistor was hot after about 15 minutes
Old July 11th, 2011, 06:35 PM   #14
SizeMatters
Sketchy, Son....
Then I would fancy a guess at the ignition wiring somewhere. Instead of the resistor dropping ohms after the engine is fired, it is staying up in the 1.2ish ohms range which is making it hot. I would say you have an ignition issue somewhere.
Old July 11th, 2011, 08:29 PM   #15
Flat_Black
The Dodge Guy
Flat_Black's Avatar
sounds to be a bad control module
Page generated in 0.26401 seconds with 68 queries
