04 Superduty - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2011, 09:55 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default 04 Superduty
2004 Superduty
6.0L
4x4
CCSB
Do these trucks use unit bearings in the front? Helping a buddy out this weekend and I'm gathering knowledge about the job before we start, and NAPA's website is showing roller bearings. I thought a 3/4 ton SFA truck would have unit bearings.
Help.
Old June 7th, 2011, 09:58 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
unit
H.o.r.e
Old June 7th, 2011, 10:07 PM   #3
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Awesome, Thanks for the help, but I'm not done yet
Which is correct, loctite or antiseize on the bolts holding the unit bearing to the knuckle?
I try to follow torque specs as much as possible. Do you know the torque specs of those bolts and the spindle nut?
Old June 7th, 2011, 10:09 PM   #4
joescamaro67
joescamaro67's Avatar
the bolts are torqued two clicks past real f***ing tight,and i think the spinle nut is like 180.
joescamaro67 is offline   Reply With Quote
Old June 7th, 2011, 10:17 PM   #5
Bones
Bones's Avatar
I never use antiseize or loctite on the unit bearing nuts. They have a knurled face on the flange to lock the nut.
There isn't a spindle nut on unit bearings.
One tip. When you go buy a new unit bearing, it will not have the 4 unit bearing studs on it. You can either go buy new ones from the dealer (get new nuts too), or you can try to remove the old studs and put them on the new bearing. that process is a serious pain in the ass. You have to double nut the stud and apply a serious amount of heat on the unit bearing to remove the stud. Without a torch, you'll never get the studs removed.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 8th, 2011, 03:56 PM   #6
HVYRTFT
Reed my teef
HVYRTFT's Avatar
couldn't I just use a hydraulic press and press the studs out, heating if needed?
Old June 8th, 2011, 04:15 PM   #7
masterbeatty
masterbeatty's Avatar
i dont see why you couldnt. we have done the bearings on my dads excursion, same thing. and we got the wrong bearing once, it had the course studs not the fine so we swapped them and they came right out no problems.
Page generated in 0.20470 seconds with 44 queries
