Fixed now what is it worth? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2011, 09:02 PM   #1
Jeep ZJ
Jeep ZJ's Avatar
Default Fixed now what is it worth?
Im going to be trading one of my paintball gun set ups soon and I havent had it shooting right for like a year. Ive replaced o-rings and lubed it up good and still not shooting right. It wont reload to shoot another paintball. Its a Piranha GTI with 3,5,8 round burst and full auto. its an electric gun if that helps. Let me know if pic would help. Any help would be great thanks.
since that ^ is fixed now I need to know what it is worth?? It's a Piranha GTI with 3,5,8 round burst and full auto. Comes with mask, gun, 14" Sniper barrel", 9oz. and 20oz. tanks that i just filled today, hopper, and 500 paintballs. Whats its worth??
Old June 7th, 2011, 09:31 PM   #2
Medic8
You call, we haul.
Medic8's Avatar
First, check your air pressure. If you don't have enough air/ CO2 in your tank, it won't recock. Next, check your velocity adjuster. If you have it cranked all the way in because you're trying to up your FPS, it might make the spring tension too tight to recock. Also, check your valve (you'll have to pull down the front end of the gun) and make sure that it's moving free.
Basically, if you can understand how the gun is trying to work, you can fix it yourself easily. Your particular gun is a "stacked tube open bolt" meaning you've got the bolt and hammer stacked on top of each other. In the "ready to fire" position, the bolt is open, meaning a ball is free to drop in and load. When you pull the trigger, it flips a microswitch, which trips the sear. This releases the hammer, which via spring power is pushed forward into the valve body. The valve body has a pushrod which the hammer hits, pushing the valve to open. When the valve opens, air is passed through the bolt, which fires the paintball. Air also pushes the hammer back, and since the hammer is physically connected to the bolt, it returns it to the "ready to fire" position.
Things that can impede the function... low input pressure. Low pressure at the valve body (plugged air line/ brass "filter"), sticking valve, sticking hammer. Low battery can be a bitch too, since the solenoid that trips the sear might not have enough power to do just that. If you've got air, and good batteries, and everything is moving well, you might want to look at your anti-chop eye (if your gun has one). It's a photovoltic (light sensitive) switch that trips when a ball falls past it. If it's got paint/ dirt/ dog shit covering the switch, it thinks there's a block, so it won't allow the gun to fire.
Give that a shot, see where it gets you. If nothing else, run it over with a Jeep, and at least you'll feel better.
Old June 7th, 2011, 09:38 PM   #3
tweak177
Say what?!?
tweak177's Avatar
Originally Posted by Jeep ZJ View Post
Im going to be trading one of my pitbull gun set ups soon and I havent had it shooting right for like a year. Ive replaced o-rings and lubed it up good and still not shooting right. It wont reload to shoot another pitbull. Its a Piranha GTI with 3,5,8 round burst and full auto. its an electric gun if that helps. Let me know if pic would help. Any help would be great thanks.
Fixed
I really don't hate pitbulls
tweak177 is offline   Reply With Quote
Old June 8th, 2011, 02:58 AM   #4
TechJeeper
Formerly "Gr8archer"
TechJeeper's Avatar
Send a message via AIM to TechJeeper
Not sure what you did to fix it, but just FYI, many of the Electronic guns (Spiders, Parahnas, ect) use a lesser known 9.6v battery (looks just like a 9v). If you use a 9v in these guns, it might shoot, but not for long before doing the "click click" issue again. 9.6v can be found at most Paintball shops in a rechargable form.
Just a thought, incase you still have issues.
TechJeeper is offline   Reply With Quote
Old June 8th, 2011, 09:06 AM   #5
Jeep ZJ
Jeep ZJ's Avatar
good call!!! thats what its doing! i lost my charger and i replaced it with a reg 9v! hahaha i still got the 9.6v just got to find a charger. now my new problem is i can only find one paintball shop in gr the rest closed
edit: just checked and it said its an 8.4v??? same difference???
Old June 8th, 2011, 09:34 AM   #6
skife
skife's Avatar
after you shoot it the gun doesn't cock back?
the main spring has to much pressure on it back it off or cut a few coils from it.
Old June 8th, 2011, 09:38 AM   #7
Jeep ZJ
Jeep ZJ's Avatar
yeah. and ive never messed with that to make it shoot harder and faster? never touched that since i owned it.
Old June 8th, 2011, 09:42 AM   #8
skife
skife's Avatar
when was the last time you messed with it?
was it outside in the wintertime while running co2?
Old June 8th, 2011, 09:44 AM   #9
Jeep ZJ
Jeep ZJ's Avatar
last night when i took it apart but its hardly been played with and no on the winter time. besides a few shoots here and there but thats it.
Old June 8th, 2011, 10:08 AM   #10
skife
skife's Avatar
was just suggesting the winter thing because CO2 gets cold and doesn't like to expand as much.
Old June 8th, 2011, 10:11 AM   #11
Jeep ZJ
Jeep ZJ's Avatar
ok. im going to try the battery thing before i start taking it apart again.
Old June 8th, 2011, 11:34 AM   #12
Jeep ZJ
Jeep ZJ's Avatar
thanks looks like it was just the battery. now my question is what is it worth??
Old June 8th, 2011, 11:38 AM   #13
mschaffer66
mschaffer66's Avatar
Isn't a Piranha like a Kmart gun?
Old June 8th, 2011, 11:39 AM   #14
Jeep ZJ
Jeep ZJ's Avatar
Meijer's but its a real nice gun. im uploading a pic right now
Old June 8th, 2011, 11:40 AM   #15
mschaffer66
Weren't they like $60 new?
Old June 8th, 2011, 11:41 AM   #16
mschaffer66
Whats its worth??
Based on what I've saw lately, if you give it to Immortal its worth a wrister...
Old June 8th, 2011, 11:43 AM   #17
Jeep ZJ
Jeep ZJ's Avatar
it was just a battery stupid pic wont upload
Old June 8th, 2011, 11:52 AM   #18
Jeep ZJ
Jeep ZJ's Avatar
175 or 200 i cant remember. i got a deal on it when i got it..
Old June 8th, 2011, 01:12 PM   #19
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Not worth much at all, the $60 is a fair number IMO With the tanks maybe $80
Old June 8th, 2011, 01:19 PM   #20
Jeep ZJ
Jeep ZJ's Avatar
thanks for the imput.
Page generated in 0.32752 seconds with 82 queries
