noise coming from lock out - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2011, 11:08 AM   #1
motox168
Bare Bones Offroad
motox168's Avatar
Default noise coming from lock out
I recently installed a hp 44 from a 1978 f250 in my cherokee. I put new Warn Supreme locks outs on it. When I engage the lock outs and drive in 4wd I occasional get a very loude humming like noise comming form the passanger side. If I unlock the hubs and put it in 4wd It usually dosent go away. If I back up a few feet the noise will go away. Occasionaly If I leave the lock outs engaged and leva it in 4wd but back up a little bit the noise goes away. Any thoughs of what is causing this.
motox168 is offline   Reply With Quote
Old June 7th, 2011, 01:08 PM   #2
Muttly
Muttly's Avatar
What are the gear ratio's in the front and rear axles?
Muttly is offline   Reply With Quote
Old June 7th, 2011, 02:02 PM   #3
Bones
Bones's Avatar
I am guessing it is the spindle bearing (the bearing between the spindle and the axle shaft)
You don't hear it in 2wd because the axle shaft isn't spinning inside the spindle. When you put the vehicle in 4wd and the axle shaft spins while the spindle stays stationary.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 7th, 2011, 02:04 PM   #4
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I agree with Bones.....
Old June 7th, 2011, 04:10 PM   #5
motox168
Bare Bones Offroad
motox168's Avatar
the gears are matching front and rear, The whole axle was just rebuilt and that bearing was replaced but will look into it.
Old June 7th, 2011, 05:47 PM   #6
Bones
Bones's Avatar
the other alternative is to swap the lockout from driver to passenger and see if the noise follows the lockouts or stays with the spindle.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.15340 seconds with 41 queries
