2000 dodge 2500 5.9 gas surge problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2011, 07:58 PM   #1
skylar1joce2
Default 2000 dodge 2500 5.9 gas surge problem
just bought a 2000 2500 ram 4x4 5.9 gas, everyonce in a while the rpms surge 100-200, specially when just cruising down highway, replace plugs, wires, dist cap, rotor button, tcs. any other ideas
skylar1joce2 is offline   Reply With Quote
Old June 6th, 2011, 08:40 PM   #2
jaysusr
jaysusr's Avatar
Fuel pressure steady? Converter unlocking? Throttle position sensor gonzo?
Old June 17th, 2011, 10:45 PM   #3
DodgeDude99
replace the TPS sensor (throttle position sensor), what you are experiencing is the torque convertor unlocking and locking up again.
DodgeDude99 is offline   Reply With Quote
Old June 17th, 2011, 11:07 PM   #4
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Could be the trans slipping. Try changing the fluid and filter and possibly adding lucas trans slip stuff. I had the same issue with mine and this solved it. I had 95k on mine.
Silver Bullet is offline   Reply With Quote
Old June 17th, 2011, 11:20 PM   #5
DodgeDude99
is it sad that changing the TPS sensor is cheaper then changing the trans fluid these days!
when i rebuilt my trans in march, i had over $100 in just ATF+4.
you can also try drilling on the bushing in the bolt holes of the TPS, sticking some washers on the bolts, bolting the TPS back on and adjusting the voltage with a meter.
http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Page generated in 2.21596 seconds with 38 queries
