Dodge hemi sparkplug swap on ram 2500.. Brake booster in the way. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2011, 07:24 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default Dodge hemi sparkplug swap on ram 2500.. Brake booster in the way.
What am I overlooking here? How do you get at cyl 5 & 7? There is only a 2.5" gap between the coil pack area and the brake booster.
Old June 6th, 2011, 07:52 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
is it the booster or the master cylinder in the way? if its just the master drop the two bolts and drop to the side. if its the booster then you would have to pop the engine mount on that side and roll the engine up on a jack.
it might be easier to drop the booster if you can't roll the engine.
Yetti
Old June 6th, 2011, 07:59 AM   #3
crassell
crassell's Avatar
I removed the inner fender on an 05 1/2 ton to get to the driver side rear plugs easier.
crassell is offline   Reply With Quote
Old June 6th, 2011, 08:30 PM   #4
03tjsport
Red Dragons!
03tjsport's Avatar
Drop the spark plug socket in,drop a 3" extension in. Somtimes you need to use a 1" extension too. Loosen plug and remove extensions and sockets one at a time. The first one I did I was like wtf did they do that for,but now they are cake.
03tjsport is offline   Reply With Quote
Old June 6th, 2011, 08:35 PM   #5
dline
dline's Avatar
90 degree drill works pretty good on those
dline is offline   Reply With Quote
Page generated in 0.24518 seconds with 38 queries
