82 Ramcharger no crank - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2011, 01:01 PM   #1
Jleach0696
Jleach0696's Avatar
Default 82 Ramcharger no crank
bought new truck started it drove it on trailer get home go to start it and just click from the bendix .
checked grounds cleaned reinstalled
replaced starter relay with another
have 13.6v at the starter
replaced with different starter after bench test and no spin
still just the bendix engaging nothing spins
Jleach0696 is offline   Reply With Quote
Old June 5th, 2011, 01:10 PM   #2
87mopar
Web Wheeler :(
87mopar's Avatar
Can you jump the terminals on the starter while it's bolted in? Can you turn the motor over by hand ( breaker bar)?
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old June 5th, 2011, 01:29 PM   #3
Jleach0696
Jleach0696's Avatar
when jumped the bendix just engages started dont spin
motor turns over by pulling on the belts
Old June 5th, 2011, 01:32 PM   #4
87mopar
Web Wheeler :(
87mopar's Avatar
Have you tried a different battery? all the cables good? you got voltage but what about amperage? how much resistance is in the main cable from where the battery is to where the starter hooks up?
Old June 5th, 2011, 01:36 PM   #5
Jleach0696
Jleach0696's Avatar
no on battery but it has 13.6 v and started great last night before the trailering home
i just looked at the cable running from battery to starter looks kinda corroded
checking amps and ohms
brb
Old June 5th, 2011, 01:40 PM   #6
Jleach0696
Jleach0696's Avatar
lots of resistance like 25. ohms
looks like a new cable is in order hope thats all
and i need more hands to check amps
Old June 5th, 2011, 02:25 PM   #7
87mopar
Web Wheeler :(
87mopar's Avatar
yeah that is alot of resistance. if you want to check you can run a jumper cable in place. clip on to the terminal and touch it to the solenoid and see if it turns it over.
Old June 5th, 2011, 02:45 PM   #8
Jleach0696
Jleach0696's Avatar
exactly what i did
the cable ends fell off as i was pulling it out of the truck
puled one off the old truck and she starts
Old June 5th, 2011, 02:47 PM   #9
87mopar
Web Wheeler :(
87mopar's Avatar
So we're good? its the cable?
Old June 5th, 2011, 03:13 PM   #10
87mopar
Web Wheeler :(
87mopar's Avatar
i was just looking at it and was thinking to my self that would be nice to have for winter.. then i saw sold in your drive way.
Page generated in 0.25019 seconds with 53 queries
