***GONE*** 1994 ZJ Jeep Grand Cherokee ***GONE*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old June 4th, 2011, 12:48 AM   #1
Paintballpsyco236
Paintballpsyco236's Avatar
Send a message via AIM to Paintballpsyco236 Send a message via MSN to Paintballpsyco236 Send a message via Yahoo to Paintballpsyco236
Default ***GONE*** 1994 ZJ Jeep Grand Cherokee ***GONE***
***SCRAPPING WITHIN THE NEXT 3 DAYS SO COME GET IT WHILE IT'S HERE!***
Hello all, I have a 1994 Grand Cherokee with the 5.2L V8 engine. It is black and has a tan interior and 223,000 miles
Things I am keeping off it:
- Rear brakes
- E-brake cables
- Front driveshaft
- Prop valve
- Tie rod and its ends
- Front sway bar (just bar, links are cut.)
- Tail light harness's
- Leather Seats
- Washer bottle
If you think something is too high, please make an offer. I can meet in a few places for nothing extra when you buy multiple items. Also, if it is not yet listed, please feel free to make an offer for the part you are interested in. Everything will be sold on a first come first serve basis, no holding items anymore. I am up usually quite late if you prefer to come later in the day.
Prices to start:
- Dana 30 Partout listed here:
Axle Part(s): 94 ZJ Dana 30 partout - Great Lakes 4x4. The largest offroad forum in the Midwest
- Master cylinder and booster listed here:
Misc Jeep Part(s) 94 Jeep ZJ brake booster and master cylinder - Great Lakes 4x4. The largest offroad forum in the Midwest
- ECM $70
- Rear Dana 35 everything but the brake stuff $25 for both shafts, $40 for ring and pinion, $30 for LSD carrier, $30 for tube, cover and cover bolts.
- Front track-bar and body bracket $8
- CV axle shafts, ABS rings, inner and outer shafts, come with the jam nuts, and one has the castle nut thing with its little spring and a cotter pin (the old pin). $65
- 3.73 gears, Low Pinion, in great shape. Will include the carrier bolts $60 ***SOLD** (Set from a 2002 WJ Dana 30 is also available for $70)
- I also have a set from a Dana 35 with matching gear ratio available for purchase. (From the ZJ to clarify)
- Carrier for 3.73 and numerically higher gears $30
- U-joint yoke for Dana 30 $20
- Pair of hubs $30
- Pair of knuckles $40
- Calipers $30
- Differential cover and bolts $10
- Rotors, come with pads $25
- Housing, has upper control arm bushings though probably no good, the bearing caps for the carrier and their bolts. Ball joints supposedly almost new, but one side seems a bit stiffer than the other $35
- Brake Master cylinder and booster, just spent 2 days cleaning the booster and painting it, so it has a flat black paint on it now. It has the lines on it still from the master to the prop valve as well as the lines from the fluid reservoir to the HCU, and I left the prop valve bracket bolt on there. It also comes with the brake pedal and the pedal sensor. As well as the pedal travel sensor that is on the booster under the hood. The fluid reservoir could use a flush but other than that everything worked great when it was on the ZJ. $50
- Front track-bar and body bracket $5
- Rear sway bar $4
- Rear track-bar $4
- Rear control arms (all 4) $20
- 5.2L 318 V8 Engine, Was told heads were warped but it could be something else, out of the Jeep now, can load into truck bed for you, $150
- Rear driveshaft $8
- Center Console (dirty but will try to clean it up some, includes transfer case bezel $10 (6 pack will take it too)
- All interior plastics/trim between and including dashboard and tailgate, tan in color $20 or a 12 pack or something cold in bottles...
- Head light lenses with bulbs $20
- Passenger side turn signal lens and marker lenses BOTH SIDES, Passenger drive side has a couple cracks $15 (6 pack will take it too)
- Wiring harnesses for marker lights and signal lights (some bulbs good, some bad) Come with above item
- Sunroof and all the stuff for it, Make an offer
- Rear carpet. Come get it
- Rear hatch is bad on the bottom edge but good glass Wiper works as far as I know $25
- Rear hatch trim $10
- All four doors, with speakers, some rust on the bottom edges of all doors but not too bad on back doors , rust through passenger side front door, rust hole under drivers side mirror, all glass is good, power locks and all power windows work. $20 per door
- Door trim, crack in the passenger side front panel, $15 each or $40 for all 4.
- Heated Side Mirrors, $30 each or $50 for the pair
- Rear view mirror $4
- Radiator is new and aluminum, $60
- Hood is still good on the outside, a couple small rust spots though. Inside front edge had a lot of rust. Will include all hinges and hinge springs with it. $10
- Tail light lenses, perfect shape except for some dirt $40 for the pair $25 each
- Rear quarter panel glass $20 for both sides
- Front and rear coil springs $40 for the set
- Front and Rear ABS sensors (all 4), $20
- Gas tank with pump and filter and a little gas $30
- Hood light and harness Free with any other purchase
- Little 3 bolt things bolted to front bumper, seems to be a relay of some sort $5 for both
- What looks like an evap canister from drivers side under bumper, comes with lines to back of engine as well $5
- Fan shroud $10 (12 pack will take it too)
- Lower radiator support and the side brackets for $10
- ABS controller module $25
- ABS Hydraulic control unit $50
- Passenger side fender, has rust on bottom edge towards the cab, front is good $10
- Upper and Lower radiator hoses, just about new I believe; $15 for both or $5 with purchase of Radiator
- Coolant overflow bottle, come get it
- Front Grill piece $10
- Steering colum MAKE OFFER
- Assorted crap from the dashboard MAKE OFFER BASED ON ITEM WANTED
- Instrument cluster $30
- THIS IS PRETTY MUCH WHAT IS LEFT, MISC. INTERIOR PARTS AVAILABLE AS WELL.
These items have sold:
- Transmission, automatic, rebuilt around 13-15,000 miles ago, I do not have the papers for it. It is an overdrive transmission as well. It is still in the Jeep but will make deal if you help me pull it and the engine. $225
- NP 249 Transfer case, "beefed up" by previous owner; I think probably just the Chain and Sprockets but not sure. Not familiar with this model $100
- Front control arms CUT OUT
- A set of wheels, 5 rims 5x4.5 pattern, not sure on backspacing. Tires have about 20-30% tread left. There are 5 rims and 4 tires. The tire on the spare rim is a brand new Firestone Destination LE 235/75R15 (same size as the other tires). They are aftermarket rims by Panther Custom Wheels. Asking $180 with the Firestone on the spare rim, or 140 without it. As with the other stuff they are OBO.
- Infinity factory amplifier $10
- Trailer hitch receiver, Mopar, has a hitch and ball in it. Can't seem to get it out right now. $50 for both, or $40 with trade of another hitch and ball (as long as it is a 2" hitch, ball size does not matter for now)
If you want something that isn't listed, just ask, I probably have it. Also again, feel free to make an offer on something if you think the price is too high. First come first serve on everything and everything is sold as is. You can contact me by text message at any time, or by phone from noon to midnight at 810-305-2535
I have a bunch of pictures of this ZJ and parts on my photobucket: http://s24.photobucket.com/albums/c2...%20or%20Trade/
Thanks again for looking, and please have a nice day.
Paint
Paintballpsyco236 is offline   Reply With Quote
Old June 7th, 2011, 12:59 AM   #2
Paintballpsyco236
Transfer case is pending, one door may be pending tomorrow. I would like to have as much of this stuff gone by the end of the month as possible so please do not hesitate to throw an offer out. Thanks again for looking.
Pending
Old June 7th, 2011, 10:47 PM   #3
Paintballpsyco236
Added a link for some pics, also sold the transfer case, and someone is coming to take a look at the drivers side front door tomorrow so that may be gone. I will update as soon as I know about that.
Thanks again for looking, have a good night.
Paint
Old June 8th, 2011, 08:03 PM   #4
00xj74
00xj74's Avatar
Does the rear axle still have the backing plates on them?
00xj74 is offline   Reply With Quote
Old June 8th, 2011, 08:25 PM   #5
Paintballpsyco236
Nope, sorry. As mentioned in the beginning of the post I am keeping all the rear brakes. Thanks for looking though.
Paint
Old June 8th, 2011, 08:48 PM   #6
Paintballpsyco236
Updated the main post, added the tires and rims now for sale, and I am uploading some more pictures of it to the photobucket album, those should be done within the next 20 minutes or so. Thanks again for looking and have a nice day.
Paint
Old June 10th, 2011, 02:42 AM   #7
Paintballpsyco236
Back to top...
Old June 13th, 2011, 08:47 PM   #8
Paintballpsyco236
Back to top...
Old June 13th, 2011, 08:57 PM   #9
Flat_Black
The Dodge Guy
Flat_Black's Avatar
interested in the hitch,taillights,hatch if i can get spme pics and maybe the wheels.
Old June 13th, 2011, 10:09 PM   #10
Paintballpsyco236
The hitch is still on the ZJ, but I will try to pull it tomorrow and get some pics. The tail lights are also still on , but easy enough to remove once I get the hatch off. They are kind of dirty on the backs but are in perfect condition. As for the hatch, it seems to be stuck on right now lol. The bottom edge is pretty rusted out, but I will get some pics of the hatch tomorrow of it and the bad spots tomorrow for you. Did you want any other pics of the wheels or anything and were you interested in the spare tire as well or just its rim? Thanks for looking, will talk to you soon.
Paint
Old June 15th, 2011, 02:52 AM   #11
Paintballpsyco236
Dropped some prices...
Got the hitch off today, was able to open the hatch and get the tail lights off too. I will get some better pics of the hitch, hatch, and lights for you tomorrow, the ones I took today were before I got it all off of the Jeep. Were you still interested in the wheels? I only ask as I need to know soon if you wanted the tire on the spare rim or not, my brother needs it for his Blazer but you are first in line for it so... Thanks again, will talk to you soon.
Paint
Old June 15th, 2011, 07:03 AM   #12
Flat_Black
The Dodge Guy
Flat_Black's Avatar
if we can work a deal i wont need the tires.
Old June 15th, 2011, 02:43 PM   #13
Paintballpsyco236
We can work out a deal no problem. The 4 tires though are staying on the rims, I just have no use for them and no way to dispose of them right now. It is just the spare tire I am wondering about as it is brand new, never seen the road so... As far as a deal goes, if you want, send me a pm of what you had in mind. Thanks again, will talk to you soon,
Paint
Old June 15th, 2011, 09:45 PM   #14
newdodge
jeep life
newdodge's Avatar
pmed you
newdodge is offline   Reply With Quote
Old June 16th, 2011, 02:38 PM   #15
Paintballpsyco236
Responded to, rest is still up for grabs, no definites yet on anything... And again feel free to make an offer on anything, I need this stuff gone ASAP.
Paint
Old June 16th, 2011, 04:53 PM   #16
Paintballpsyco236
Got into the dif yesterday of the D35, nothing is welded in there, but there is some sort of a limited slip in it. Not sure what kind though.
Paint
Old June 18th, 2011, 12:24 PM   #17
Paintballpsyco236
Back to top, stuff has to go. Make an offer...
Old June 18th, 2011, 03:56 PM   #18
Paintballpsyco236
More pictures in the album now...
Old June 20th, 2011, 03:10 PM   #19
Paintballpsyco236
Prices dropped, updated some items, added a couple items/options. More to come this week! Thanks again,
Paint
Old June 23rd, 2011, 05:30 AM   #20
Paintballpsyco236
Back to the top. I can start parting things like the hatch or doors out if that would help at all... I really need to get this stuff out of my yard asap... Thanks again for looking,
Paint
Page generated in 0.43605 seconds with 84 queries
