1995 ranger 4.0 no spark on cyl 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2011, 10:11 PM   #1
92comanche4x4
92comanche4x4's Avatar
Default 1995 ranger 4.0 no spark on cyl 6
I have a 1995 ranger 4.0 4x4 it has no spark on the number 6cyl. i replaced the ecm, coil pack, plug wire, plug. and its getting fuel and has good compression. any ideas
92comanche4x4 is offline   Reply With Quote
Old June 3rd, 2011, 10:13 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Broken tooth on the crank reluctor wheel?
Do you have injector pulse on cly 6?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 3rd, 2011, 11:00 PM   #3
92comanche4x4
Im not sure on the injector pulse. and what is a crank reluctor wheel?
Old June 3rd, 2011, 11:12 PM   #4
GREASYHANDS
The crank reluctor is behind the harmonic balancer. The crankshaft position sensor "reads" each tooth on this to tell the ecm what cly is top dead center. This also works with the cam sensor to set timing and the fuel to the correct cly at the correct time.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 3rd, 2011, 11:16 PM   #5
GREASYHANDS
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 3rd, 2011, 11:28 PM   #6
92comanche4x4
Could it be just the cam sensor thats what i was thinking to do next. And i had no clue what a crank reluctor was im gonna have to check it out tommarow. how would i get to it take the harmonic balancer off?
Old June 3rd, 2011, 11:50 PM   #7
GREASYHANDS
you can see the reluctor with out taking any thing off the motor. Use a socket and turn the engine over while looking closely at the teeth on the wheel. If any of them look damaged replace it. Also check your injection pulse before you start to throw parts at it.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 4th, 2011, 10:27 AM   #8
92comanche4x4
cool thank you for the help im gonna check it out today
Old June 4th, 2011, 12:10 PM   #9
chris1044
chris1044's Avatar
IIRC cam sensor doesn't do anything with spark, just injection timing, but I can't remember and don't have schematics in front of me.
Have you swapped a plug wire to see if it's just a bad wire? Perhaps you got a bad coil pack?
Old June 4th, 2011, 03:48 PM   #10
92comanche4x4
plug wire and another coil pack have been swapped on
Page generated in 0.27521 seconds with 53 queries
