which speedo gear so i have correct speed - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 2nd, 2011, 02:38 PM   #1
tonkatruckon44s
tonkatruckon44s's Avatar
Default which speedo gear so i have correct speed
i need help finding a speedo gear that will make my speed correct when i downsize tires for gas mileage. right now my speeedo is pretty much on with my 37s i have a np 208 turbo 350 and 4:10 gears and i want to go down to a set of 37 bfg ta kos for gas mileage but i dont know anything about the speedo calibration or where to get the gears but i figure someone will or we all can figure it out
tonkatruckon44s is offline   Reply With Quote
Old June 2nd, 2011, 05:22 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
You have 37's and you want to go to 37's and recalibrate your speedo?
Old June 2nd, 2011, 05:28 PM   #3
Jeep ZJ
Jeep ZJ's Avatar
37" swampers and go to 37" AT's maybe?? that may make a difference because of the weight?
Old June 2nd, 2011, 06:32 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
No, weight doesn't change your speedo.
I'm guessing he want's to go to 35's and change the speedo gear to compensate.
Need to know what gears are in the t-case now (drive & driven).
Old June 3rd, 2011, 03:54 PM   #5
tonkatruckon44s
my bad i mean 33 bfgs ta ko
Old June 4th, 2011, 12:20 PM   #6
Jeeperz Creeperz
GL 4x4 Vendors
The NP208 uses a drive and driven gear so you need to figure out which gears you have now so that you can change them. Otherwise you can use a speedo reduction box to screw between the speedo output and speedo cable to drop it by a percentage.
Old June 4th, 2011, 07:49 PM   #7
tonkatruckon44s
where do i get a speedo reduction box
Old June 8th, 2011, 01:41 PM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Check with Bob's Speedometer in Howell
or
http://www.transmissioncenter.net/sp...atio%20adapter
Old June 9th, 2011, 11:24 AM   #9
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
or
Cool, a Michigan company at that. thanks
RIP FULLSIZE4LIFE
Page generated in 0.34771 seconds with 50 queries
