Plasma Table ***SOLD!!!!**** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 2nd, 2011, 09:46 AM   #1
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Default Plasma Table ***SOLD!!!!****
5x10' Lock Former plasma table. Model VIS 1800
Everything works.
Missing cutter.
110 volt onboard controller.
Hooks up to a computer via a printer port and you need to supply your plasma cutter and software of choice.
There's a bunch of cables and wires/connectors that comes with this as well.
Pics:
Controller:
PM monsterman with any additional questions- I'm only listing it for him. If he doesn't get back to you in a day, then contact me and I'll check in with him.
I'll be on the road all day friday and at the race at twisted on Saturday. I'll do my best to check in on this thread tomorrow night and then again Sunday if it doesn't sell over the weekend
$3000 firm!!!!
SANDVIPR is offline
Old June 2nd, 2011, 10:11 AM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
You should post the thickness it will cut.
chadcooper55 is offline
Old June 2nd, 2011, 10:17 AM   #3
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
It's all dependant on the plasma cutter and speed setting you program into it.
I've seen them cut over 1" with a good plasma unit.
SANDVIPR is offline
Old June 2nd, 2011, 10:59 AM   #4
chadcooper55
Can you use any normal hand held plasma cutter or does it take a special on for the table?
Old June 2nd, 2011, 11:05 AM   #5
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
The biggest thing is to use a plasma machine that you can get differnt heads for. I've seen some nice work done with a hand held trigger mounted on an adjustable mount and I've seen crappy cuts with a dedicated machine head with bad tips.
This one has a roller-ball style mount for a table-style tip to be inserted into, but that could easily be changed out.
We have used Hypertherm and ESAB units and both worked great.- both of those companies have several different options as their machines are designed for production use.
I have not had ANY experience with Lincoln or Miller units on one of these machines, but I would not rule them out.
SANDVIPR is offline
Old June 2nd, 2011, 11:18 AM   #6
chadcooper55
Alright, that sounds good! I don't have the cash to buy it at the moment but I will talk to a couple friends and see if they would be interested in pitching in on it. If you could find a link to which table it is or a model number that would be great so I can see what it is exactly and the new price. We got a bridgeport mill, a radial arm drill press and a bender set up so a lathe, iron worker and plasma table are the next 3 big purchases.
Old June 2nd, 2011, 11:25 AM   #7
Destr0
Destr0's Avatar
I may have a used Hypotherm plasma available soon that should go right on this table.
We have two of them, both will cut up to 3" steel, but I believe we have an older Hypotherm 200 amp plasma cutter getting sold soon.
If anyone buys this and needs help getting it setup on a computer, that is what I do for a living (IT Manager for a fortune 500 steel service center).
See my avatar for an example of what you can do with a CNC plasma cutter. The Jeep logo is 3/8" thick floor plate.
~K
Destr0 is offline
Old June 2nd, 2011, 11:33 AM   #8
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Thanks guys. I'll get the model # and other info this weekend as well. I know that the shop it originally came from spent big $$$ on it- like to the tune of $80K, but that was probably turn-key with everything including help programming.
Monsterman got it as part of a liquidation deal when the place went belly-up.
We just decided to go a different direction with our shop.
SANDVIPR is offline
Old June 2nd, 2011, 01:01 PM   #9
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
There have been a few questions about it being a water-table. It is not, but it is fully open underneath and anyone could build a simple water-tray on castors or rollers for it.
We had it set-up for a ventilation/filter system.
Now that I think about it, I believe that we can show you that the actuators/drive motors work by programming it to move maually. It should only take a few minutes to hook it back up and run a couple sweeps for anyone interested.
SANDVIPR is offline
Old June 2nd, 2011, 03:26 PM   #10
Destr0
Destr0's Avatar
80K isn't a bad price. Our new one we bought in 09 was discounted 50% and still set us back $700K (about 1.1M after pouring new foundation to support it and all the other stuff it needed) like a new crane...
Destr0 is offline
Old June 2nd, 2011, 03:28 PM   #11
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Yeah- he thought it was just over $100K new, but I thought that was high. Maybe not.....
SANDVIPR is offline
Old June 2nd, 2011, 04:51 PM   #12
Destr0
Destr0's Avatar
Yeah, I checked it out and a 5x10 table is aprox 20K for just the table, the plasma cutter itself is another 20-40K for a propper 400 amp Hypotherm unit new, and that is just the price of the parts. That does not include any setup/support or PC to control them.
:-) $3K is a smokin deal if anyone is looking to get into CNC cut parts. Way too small for anything we use (we have three tables, the smallest of them is 96X240).
Destr0 is offline
Old June 2nd, 2011, 09:18 PM   #13
welderboyjk
Inquiring minds want to know;
approximate age?
gantry design?
single or double side drive?
ballscrew or rack & pinion?
torch height control?
welderboyjk is offline
Old June 2nd, 2011, 10:34 PM   #14
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
approximate age? 10 years guve or take
gantry design? Yes
single or double side drive? Double
ballscrew or rack & pinion? Rack and pinion
torch height control? Not yet- that was on the "to get" list
I'm going from the best of my knowledge on that stuff. We do have all the origional ppwk, sales reciept, and set-up books. Sorry- I was in a hurry and didn't look at th total bill on the 2nd or 3rd page....
See more info and pics above on mail listing.
SANDVIPR is offline
Old June 5th, 2011, 04:05 PM   #15
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Ttt
SANDVIPR is offline
Old June 7th, 2011, 10:05 AM   #16
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Sale Pending
SANDVIPR is offline
Old June 8th, 2011, 09:11 AM   #17
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Tentatively SOLD!!!! just waiting for pick-up of unit. Thanks guys!!!!
SANDVIPR is offline
Old June 8th, 2011, 04:04 PM   #18
tonka toy
It's got a HEMI!
tonka toy's Avatar
Bu.....Bu.....Bu.....But I wanted it
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline
Old June 8th, 2011, 04:36 PM   #19
Bullet
Bullet's Avatar
Bu.....Bu.....Bu.....But now its going to be mine!!
Bullet is offline
Old June 9th, 2011, 09:19 AM   #20
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Yes- Thanks Bullet- I couldn't think of your screen name on my last post....
SANDVIPR is offline
Page generated in 0.47021 seconds with 83 queries
