steering assist question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2011, 10:28 PM   #1
muddcherokee_09
jeeper for life
muddcherokee_09's Avatar
Default steering assist question
i want to run full hydro steering but was wondering can you do the assisted setup with a double ended ram, tapped gearbox and then just no connect the steering linkage. basically just use the gearbox as an orbital valve
muddcherokee_09 is offline   Reply With Quote
Old June 2nd, 2011, 06:54 AM   #2
muddcherokee_09
jeeper for life
bump
Old June 2nd, 2011, 03:23 PM   #3
jeepguy74
jeepguy74's Avatar
i had the same question but never got a straight answer...
let me know if you find out....
Old June 2nd, 2011, 05:24 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
The gearbox doesn't work as an orbital valve. When you tap the gearbox it sends fluid to the ram when the gearbox has high resistance to turning (thus the assist).
If you don't connect the steering you won't get resistance until full lock so you'd have to do a lot of turning to get the ram to work.
Old June 4th, 2011, 03:52 PM   #5
muddcherokee_09
jeeper for life
ok thanks that clears it up
Page generated in 0.18199 seconds with 38 queries
