Brake Residual Valve question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2011, 07:00 PM   #1
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Default Brake Residual Valve question
I have a 4 wheel disc set-up on the truggy and I am wondering if I would need a set of these valves to maintain the 2 psi line pressure to the calipers. I have a 4 wheel disc hydroboost MC and an adjustable Prop valve with cheby 3/4 ton calipers at all four corners.
Thanks
Old June 1st, 2011, 09:15 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
residual pressure valves are only used on drum brakes not needed on disc brakes unless the brake master cylinder is located below the highest point in the system.
Old June 1st, 2011, 10:13 AM   #3
Not always. Lot of semifloat applications use them because wobble/runout/bend in the axle flanges/rotor causes the rear pads to push out a little causing a soft pedal.
I would run it, and see. I didn't require one on my old toyota or my current Jeep.
Old June 1st, 2011, 12:23 PM   #4
Sandals
Fucking Zen as Shit
Sandals's Avatar
I'm running a 2PSI one to the rear disc's on My YJ, it helped to firm up the pedal significantly.
Old June 1st, 2011, 07:22 PM   #5
bigblockford79
Big Block Ranger
I was figuring on just running it and seeing what happened, but considering it involves the most important system on the whole vehicle I decided it was worth asking about.
Thanks for the input.
Old June 1st, 2011, 09:03 PM   #6
Dylan
Dylan's Avatar
ran the 2 psi on my old setup. FF dana 60 rear with 1/2 ton chevy front calipers. It defiantly helps pedal pressure. I went from needing to double pump to perfect braking.
Page generated in 0.24041 seconds with 41 queries
