dry rot - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2011, 11:51 AM   #1
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
Default dry rot
I did some searching but came up empty handed.
My trailer tires are a year old and are starting to dry rot to all hell. I do not put any type of tire cleaner like armor all on them. I do apply stuff to the tire that is approved by the tire manufactures and does not contain petroleum or silicone. I keep them covered 99% of the time it is not in use as well to protect against the sun's uv rays. Is there anything else i can do to try and stop this from happening? What works for some of the guys on here? The conventional wisdom i have found online does not appear to work very well for me. I am going to be buying new ones here soon and do not want this to happen again so quickly.
tctrojan17 is offline   Reply With Quote
Old May 30th, 2011, 12:01 PM   #2
I suck cocks. Lots of them.
locally famous
lower the psi when not in use, might help
Old May 30th, 2011, 12:04 PM   #3
REXG
REXG's Avatar
another thing that helps is to put it on jack stands if possible keeping the tires from touching the ground.
REXG is offline   Reply With Quote
Old May 30th, 2011, 02:00 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
when i store my boats for the winter i put the axles up on blocks and let all the air out of the tires. in my experience it has kept them from rotting. a black garbage bag over the tires will keep the sun from getting to them but leave it open in the back for ventilation.
Old May 30th, 2011, 10:52 PM   #5
scottie
Eye candy
scottie's Avatar
My trailer is parked on asphalt in the Georgia sun, i have no dry rot problems.
i'd move to Georgia, either that your the tires you have were old when you got them or low quality.
scottie is online now   Reply With Quote
Old June 4th, 2011, 10:43 PM   #6
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
Looks like Georgia here i come haha.
I will try lifting the trailer off the ground, letting air out of tires, and putting bags over them. If this happens again then you are going to have a new neighbor scottie.
Old June 4th, 2011, 11:17 PM   #7
capone
capone's Avatar
I was thinking the same thing. I remember a thread a while back about someone buying "new" pop up trailer tires there were actual manufactured like five years ago. Isn't there someway to read the #'s on the tires to tell when they were manufactured?
capone is online now   Reply With Quote
Old June 4th, 2011, 11:21 PM   #8
DirtyChevy
GOT MUD?
DirtyChevy's Avatar
Send a message via AIM to DirtyChevy
yes there is.. i worked at discount tire and just because your buying "new" tires don't meen there newly manufactured. we had some in the store that were 10 years old. sounds like u have a bad batch of tires my friend.
DirtyChevy is offline   Reply With Quote
Old June 5th, 2011, 10:20 PM   #9
littletrucker
I'd hit that
littletrucker's Avatar
Look on the tires for some numbers in a small oval- granted there is a lot of numbers but one is the built date on the tires
should look like this
which means the tires are made in the 7th week (07) OF 06- that is just in my case look on your tires- these were near the dot marking but depending on who made them it could be anywhere
Page generated in 0.51062 seconds with 50 queries
