Ford Escape Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 26th, 2011, 09:33 PM   #1
kickstand
circling the drain
kickstand's Avatar
Default Ford Escape Question
I was test driving a ford escape for the little lady today. When getting on the brakes hard it had this interesting clunk in the rear end that felt like the whole rear axle was shifting (yes I know it is IRS).
This was an AWD/4WD model. Is it possible that this has something to do with the u joints? Thats what the used car guy kept saying he thought it was, you felt nothing on acceleration, only during hard braking right before you would come to a stop.
It was pouring rain, so during the shake test to see what was loose i couldn't exactly lay under there and figure it out.
Is this a common issue? Easy fix?
She really liked this particular car, and it seemed like a decent car, so I don't want to rule it out yet.
Old May 26th, 2011, 11:53 PM   #2
Bones
Bones's Avatar
I would guess it would be more of a link/arm mount or sway bar mount rather than U joints.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 4th, 2011, 11:26 AM   #3
88fordman
88fordman's Avatar
typically i feel driveshaft u-joints on accel. they are known for bad rear shocks. also, was it disc or drum in the rear? the disc brakes like to seize up and that could give you some noise.
lastly, I don't do a ton of them but the rearends like to leak and it could have chewed itself up.
88fordman is offline   Reply With Quote
Old June 4th, 2011, 11:51 AM   #4
Bishop
Bishop's Avatar
Year? Miles?
Old June 4th, 2011, 11:58 AM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Isn't the Escape a front-wheel drive unless it's in 4wd?
I'm guessing it's something binding and releasing just before the back end comes down when braking, like the stuff mentioned already (shocks, a-arm, sway bar, brake pads, motor mount).
Old June 4th, 2011, 08:12 PM   #6
Yota Bill
Yes they are, and 4wd (if you want to call it that) is auto, cant be engaged by the driver
My DD is an Escape, as it is a vehicle that fits my needs (room for the dogs and/or cargo in the back, ability to tow a bit, decent fuel milage, 4WD/AWD for winter, lack of a lever keeps me from getting stupid with my DD)
I would be taking a close look at the links in the rear, they are woefully exposed and could have been hit by something and bent, or possibly just worn bushings, etc.
Old June 9th, 2011, 09:48 PM   #7
88fordman
88fordman's Avatar
Sorry about the delay. Yes that is all true, but I do see driveshaft u-joints on these go bad. My wife drives an 03, we really like ours.
Page generated in 0.30484 seconds with 44 queries
