Ranger Speedometer Gear Questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 25th, 2011, 11:30 AM   #1
greenmeanie
greenmeanie's Avatar
Default Ranger Speedometer Gear Questions
I need a different gear for my '94, 4cyl, 5 speed, 2wd Ranger.
Anyone know what year and models would use the same gears?
After browsing the web a bit with my phone, it looks like Ford speedo gear #'s don't match up to the Jeep chart I have at home; so I need to know what gear I need I suppose.
I had 3.55 gears and swapped in 4.10's.
My tire size is 25 or 26 inches (205/60/15)
If any of you Ford guru's know what gear I need or where to get it, please let me know.
Thanks!
-Kevin
greenmeanie is offline   Reply With Quote
Old May 25th, 2011, 11:45 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
these gears seem to be really hard to come by.
There was a color code (color of the plastic gear) to gear ratio chart on therangerstaoin somewhere, i've used in the past.
I probably have one or two laying around, i think i have a pink and red in my tool box.
If they are the ones you need, send me a PM and i'll dig them up for you.
Old May 25th, 2011, 08:13 PM   #3
greenmeanie
I would love it if you could check into if you have those gears. I imagine I need whatever one comes with the 4.10 axles. I will check that site when I can use a computer; it is a pain trying to look stuff up with my phone.
Old May 26th, 2011, 06:35 AM   #4
fsumotorhead
N8KVB
http://www.therangerstation.com/tech...peedogear.html
do you know which color is currently n the truck?
Old May 26th, 2011, 07:06 AM   #5
greenmeanie
I will have to look Tuesday on my day off. I had 3.55 factory gears if you know off hand what color went with those gears from the factory. That link is just what I was looking for though, thanks.
Old May 26th, 2011, 08:04 PM   #6
bigblockford79
Big Block Ranger
bigblockford79's Avatar
ANY Ford vehicle that is 4wd or has a manual transmission will have the correct gear design for your transmission. There were only 2 styles made, those for 2WD auto trans and then 4wd and Manual trans.
Here is a site to help you figure out what number of teeth you need for the driven gear. A junkyard might be the best place to find one cheap, or search online and you will find them for around $15-20 ea.
http://www.tciauto.com/Products/Tech...eedo_gears.asp
Old May 31st, 2011, 04:45 PM   #7
greenmeanie
I need a 24 tooth gear. If anyone has one, let me know please. Thanks.
Old May 31st, 2011, 08:30 PM   #8
greenmeanie
Forgot to ask, what model is the 5 speed 2wd? I couldn't find a tag on it anywhere.
Old May 31st, 2011, 09:26 PM   #9
bigblockford79
Big Block Ranger
Should be a Mazda M50D-R1, I will look for a gear when I get home in the AM and in the JY tomorrow since I will be headed there for some stuff.
Page generated in 0.22774 seconds with 50 queries
