Alternator HELP! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 25th, 2011, 07:43 AM   #1
harry lague
Blue Oval To The End
harry lague's Avatar
Default Alternator HELP!
I have 1994 F150 did the motor swap to a 351W and it's not charging. The alternator is good. Is there any way to change my existing alternator into a one wire?
harry lague is offline   Reply With Quote
Old June 2nd, 2011, 05:47 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Not easily done on the internally regulated alternators.
I'd guess that one of the three regulator wires is not hooked to the proper source.
Old June 11th, 2011, 10:23 PM   #3
insaneoffroader
insaneoffroader's Avatar
very easy, check this website out. guy knows his chit!
http://www.fordfuelinjection.com/?p=75
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old June 13th, 2011, 12:01 AM   #4
Daddy Dan
SBF Nut
Daddy Dan's Avatar
Its most likely the anticipation wire. Its the single small wire that runs by itself to the alternator, usually green. Those often corrode, break, or rub through and short. Inspect that wire from end to end and you may find your problem.
Daddy Dan is offline   Reply With Quote
Page generated in 0.24437 seconds with 35 queries
