d30 axle shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 24th, 2011, 10:00 AM   #1
2fst4you
2fst4you's Avatar
Default d30 axle shaft
Need 2 passenger dana 30 long inner axle shafts
Old May 24th, 2011, 10:06 AM   #2
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
2 of them? did you break the new one already?
Old May 24th, 2011, 10:38 AM   #3
2fst4you
2fst4you's Avatar
The new one isn't the right shaft for some reason. Its the same spline but like an inch too long.
Old May 24th, 2011, 10:57 AM   #4
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
cut it!!
Old May 24th, 2011, 11:21 AM   #5
dmcjeep
dmcjeep's Avatar
What yar are you looking for? CJ or YJ or what? CJ's used both narrow and wide track de[ending on the year.
dmcjeep is offline   Reply With Quote
Old May 24th, 2011, 02:33 PM   #6
2fst4you
2fst4you's Avatar
Looking for a TJ shaft. Cut it how....
Old May 24th, 2011, 02:42 PM   #7
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Cut the spline down
H.o.r.e
Old May 24th, 2011, 02:53 PM   #8
Complete Off Road
Complete Off Road's Avatar
You can use a chop saw to cut the extra inch off the spline end. You should check how much spline you'll have left tho.
I have a complete long side assembly (inner, u-joint, outer, and unit hub) from a 2000 TJ at home that I would sell. PM me if you want details. A complete assembly makes trail swaps much easier.
Complete Off Road is offline   Reply With Quote
Old May 24th, 2011, 07:21 PM   #9
2fst4you
2fst4you's Avatar
I need the shaft only right now. I need to fix mine then ill look for a spare. Its about 2 in off id say cant cut that much spline off. Scott any luck finding another shaft at ur place?
Old May 24th, 2011, 11:46 PM   #10
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I have 2 I will sell ya for $100
Old May 25th, 2011, 12:32 PM   #11
2fst4you
2fst4you's Avatar
Ill take one for now. Is it a TJ shaft? Also its a 2 hour drive to your place can you meet me somewhere closer or sell it to me a little cheaper? Thanks.
Old May 27th, 2011, 12:33 PM   #12
2fst4you
2fst4you's Avatar
any other shafts out there
Page generated in 0.16606 seconds with 59 queries
