Jeep wont start effing thing is pissing me off - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 20th, 2011, 09:12 PM   #1
mojave01x2
mojave01x2's Avatar
Default Jeep wont start effing thing is pissing me off
Coming up with 2 codes p1345 crankshaft pos sensor/cam shaft sensor failure, and P0340 cam pos sensor circuit fault. I got a new crank pos sensor ran a little better but still stalling. Installed a new distributer that had a new cam position sensor. nothing different. If i dont get this thing running soon inm going to just lite it on fire and roast mashmallows.
mojave01x2 is offline   Reply With Quote
Old May 20th, 2011, 09:15 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
great post, dont be so descriptive next time
Old May 20th, 2011, 09:15 PM   #3
MiNi Beast
MiNi Beast's Avatar
play with it and get back to us.
Old May 20th, 2011, 09:16 PM   #4
MiNi Beast
MiNi Beast's Avatar
don't you know all motors have a disb so yeah what else you need to know?
Old May 20th, 2011, 09:25 PM   #5
mojave01x2
mojave01x2's Avatar
ok i take the distributer cap off i can move the rotor side to side about 1/8" or so not spinning but side to side almost like the bearing is worn?
Old May 20th, 2011, 09:26 PM   #6
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
It helps to know what year it is, motor size and all that too........for all we know you got a mexican powered cj-5 and pedro went on strike.....
Old May 20th, 2011, 09:29 PM   #7
mojave01x2
mojave01x2's Avatar
its a 1996 jeep cherokee 4.0l been messing with the distributer timing for a while and cant seem to get it to start and run for longer than a second. got gas and spark
Old May 20th, 2011, 10:10 PM   #8
littletrucker
I'd hit that
littletrucker's Avatar
did it run prior to this? have you done anything that may have caused this? (i.e pulled the distributor)
I think the real problem might be that you have a "distributer", id swap it out for the real deal "distributor"
Old May 21st, 2011, 06:06 PM   #9
mojave01x2
mojave01x2's Avatar
Bump i really need this project finished
Old May 21st, 2011, 06:57 PM   #10
creeping death
I'm that guy.
creeping death's Avatar
go out to the driveway, reach in your pocket, grab whatever money you have and throw it at it.
It may work, after all....it is a JEEP.
Old May 21st, 2011, 08:02 PM   #11
mojave01x2
mojave01x2's Avatar
Really could use some real advice...found there is three wires to the distributer pickup sensor I unplugged it and found one brown/tan has 5v one blk/blu goes to ground and a purple/wht also has 5v. I am assuming one of these wires is suposed to bring the signal to the ecm but somehow its crossed im not sure wich one is the return wire.
Old May 21st, 2011, 09:00 PM   #12
littletrucker
I'd hit that
If you wanted some more help you need to answer some more questions
Page generated in 0.24087 seconds with 59 queries
