Crossover steering options - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2011, 12:18 PM   #1
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Default Crossover steering options
Ive come across 2 steering options that dont require to use high steer knuckles. Both keep the tie rod over the knuckle but seem to have their own advantages and disadvantages.
This one seems to put a lot of stress on one single sheer bolt, but also gives you a longer and hopefully flatter drag link.
This design would give you a somewhat shorter drag link but then you could make it so it would match your track bar angle perfectly.
What are your guys opinions on these options or is there a different way that I missed.
Old May 19th, 2011, 10:44 AM   #2
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
do you run saftey washers between the tie rod and the knuckle?
Old May 20th, 2011, 08:06 AM   #3
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
60 views and no one has any advice, experience, or ideas
Old May 20th, 2011, 09:04 AM   #4
littletrucker
I'd hit that
littletrucker's Avatar
Ridin dirty had a thread were he ran the style where the drag link hooks into the other bar, it really moves that back and forth (rotates it) as you steer. Id suggest going to a true high steer setup
Old May 20th, 2011, 09:54 AM   #5
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah I would prefer a true high steer but thats just not in the card right now
was his problem from bad bump steer?
Do you have a link to that tread so I could look it up?
thanks
Old May 20th, 2011, 10:06 AM   #6
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
Interested in hearing more comments as well..........................
Old May 20th, 2011, 12:14 PM   #7
littletrucker
I'd hit that
Ill look for it, but I don't remember which forum he posted it in- cant find it- im pretty much useless
Old May 21st, 2011, 05:54 PM   #8
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Still looking for any advice
Old May 23rd, 2011, 07:28 AM   #9
trail11591
in for the opinions really like to hear about if anyone had problems shearing off the bolt
trail11591 is offline   Reply With Quote
Old May 23rd, 2011, 10:39 AM   #10
liv2mx
i like jungle gym's.
liv2mx's Avatar
been running this setup for 5 years now..grade 8 bolt no issues.
ID:	79278   Click image for larger version
Old May 24th, 2011, 10:14 PM   #11
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah but that bolt doesn't hold both the drag link and tie rod together, not as much stress.
Old May 25th, 2011, 08:43 AM   #12
littletrucker
I'd hit that
Yea its a true high steer setup- just do it
Old May 25th, 2011, 09:11 AM   #13
liv2mx
liv2mx's Avatar
you want to try and keep your track bar and drag link as close to the same length as you can.
Old May 25th, 2011, 09:37 AM   #14
MiNi Beast
MiNi Beast's Avatar
I ran the drag link under the knuckle and drag link to the top of the knuckle on my set up on my XJ with 37" grade 8 bolts and ran great, had no issues with bump steer and it turned great.
Old May 28th, 2011, 06:24 PM   #15
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Anymore ideas I would really like to keep the tie rod over the knuckle
Old May 28th, 2011, 07:09 PM   #16
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
If you have to put the tie rod below the knuckle I would suggest the solid aluminum tie rod like I have. They are expensive but tough as nails. Contact rocksolid performance in cedar springs and they can build you one. The 1 1/2" like I have is $25 a foot And they can drill and tap it for hiems. You can see it in my build thread in my Sig.
Old May 28th, 2011, 09:09 PM   #17
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
do the rocks chew up the tie rod?
Old May 28th, 2011, 09:18 PM   #18
chadcooper55
The rock solid guys use it for their links and steering. It seems to hold up very well.
Old May 28th, 2011, 09:21 PM   #19
MiNi Beast
MiNi Beast's Avatar
aluminum links are stronger then the dom considering weight to strength ratio will it stay shinny and polished, no, it will scratch but it is worth the money. when I co links and air shocks on my rig I'll be running them links as well
Old May 28th, 2011, 09:27 PM   #20
chadcooper55
The aluminum will flex and pop back also where steel just bends. It is not cheap but I am glad I went with it.
Page generated in 0.26422 seconds with 84 queries
