pressing a rear D60 inner hub bearing. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 16th, 2011, 04:57 PM   #1
Bruster
Default pressing a rear D60 inner hub bearing.
Well the bearing was in pretty bad shape so i replaced it..now looks like the only way for it to go back on is using a press.This would require me to pull the whole axle out form under the jeep and taking it to be done.Anyway i can get the inner passenger side bearing onto the spindle without using a press?
Axle is a 75 gmc dana 60
thanks,
Eric
Old May 16th, 2011, 04:59 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Bearing should be in the wheel hub held in by a grease seal (just like old school front wheel bearings). It should slide onto the spindle without needing any force.
Old May 16th, 2011, 05:02 PM   #3
Bruster
i wish it was that easy haha....def is gonna require some force for it to get back on there
Old May 16th, 2011, 05:04 PM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
thats weird
H.o.r.e
Old May 16th, 2011, 05:06 PM   #5
Bruster
yeah thats what i figured.Always thought the hib assembly should slide right off when the outer bearing/nut is off the spindle.When i took it off it wouldnt even slide off....so maybe the wrong bearing was in there.
Old May 16th, 2011, 05:09 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
did you buy the new one yet?
H.o.r.e
Old May 16th, 2011, 05:11 PM   #7
Bruster
yup..used the old part number off the bearing.
it was a timken 28678
Old May 16th, 2011, 05:13 PM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
did you pull the other side apart and see if its the same ?
H.o.r.e
Old May 16th, 2011, 05:26 PM   #9
Bruster
no...im afraid too lol
Old May 16th, 2011, 05:32 PM   #10
bigbchevy
missmrgreenagain
bigbchevy's Avatar
i would try that
H.o.r.e
Old May 16th, 2011, 05:35 PM   #11
Bruster
i suppose i could
Old May 16th, 2011, 05:35 PM   #12
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Go get the GMC bearing like kevin said, u got the wrong one. I think...
Old May 16th, 2011, 05:42 PM   #13
Bo's Cj 7
Bo's Cj 7's Avatar
Bearing either rusted or spun and welded itself to the spindle, if you press on the new bearing onto spindle how are you going to press the seal into the hub. Maybe picture would help to understand
Bo's Cj 7 is offline   Reply With Quote
Old May 16th, 2011, 07:04 PM   #14
Bruster
I got it on there....had to replace the hiems on the track bar..ill br able to take her for a spin tomorrow and see how it is.Josh I just got the same one that was on there..Dbag at autozone wouldn't listen when I said take this part number and search the data base.
Old May 16th, 2011, 07:14 PM   #15
Rub it down with some emery clothe in the future and see if you can clean it up a bit.
Old May 16th, 2011, 07:17 PM   #16
Bruster
If everything goes as planned im gonna try to make it to RV memorial weekend
Old May 17th, 2011, 12:07 PM   #17
Jeeperz Creeperz
GL 4x4 Vendors
It is that easy.
If it's not working that way you need to fix something.
Hope it works for you.
Old May 17th, 2011, 12:15 PM   #18
Trail Junkie
iamfawkinwithyou
Hiems weren't that old or giving me any issue WTF?
Page generated in 0.38172 seconds with 77 queries
