Project 1940 Ford - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 15th, 2011, 07:28 PM   #1
IDIeselman
IDIeselman's Avatar
Default Project 1940 Ford
Having not weighed anything yet but my best guess is I'll drop about 400+ pounds. Channeled the 1940 cab to sit lower on the frame and will be building the floor pan to match the 79 f150 frame mounts. Already have new rockers,cab corners and all new chrome. It will be built for hot street/pro street. After the body work it gets a nice shiney coat of 2010 candy red pearl metallic. I'm keeping everything powertrain wise I have now just doing the cab swap. The running gear in the pic is just a mock up junker. It sucks saying good bye to the 79 cab but it's all for the good of the order.
ID:	79010   Click image for larger version
Name:	1940 FORD2.jpg
ID:	79011   Click image for larger version
Name:	1940 FORD3.jpg
ID:	79012   Click image for larger version
Old May 15th, 2011, 07:37 PM   #2
steveo
In the band!
Originally Posted by IDIeselman View Post
Weight that is, Have not weighed anything yet but my best guess is I'll drop about 400+ pounds. Channeled the 1940 cab to sit lower on the frame and will be building the floor pan to match the 79 f150 frame mounts. Already have new rockers,cab corners and all new chrome. It will be built for hot street/pro street. After the body work it gets a nice shiney coat of 2010 candy red pearl metallic. I'm keeping everything powertrain wise I have now just doing the cab swap. The running gear in the pic is just a mock up junker. It sucks saying good bye to the 79 cab but it's all for the good of the order.
Thumbs down, 4x4's are more fun. Are you going through your mid life crisis already?
Old May 15th, 2011, 07:39 PM   #3
littletrucker
I'd hit that
littletrucker's Avatar
Id swap the cab and keep wheeling it!
Looks like it could be sweet either way
Old May 15th, 2011, 07:51 PM   #4
IDIeselman
IDIeselman's Avatar
I guess I should have been more definitive, Pro street mud class. I'm just swapping the 1940 cab for the current 79 cab of my mud truck. As for the mid life crisis, Yes and it sucks!
Old May 15th, 2011, 08:00 PM   #5
boggin-machine
boggin-machine's Avatar
keep the 79 cab. thats to pretty of a truck to take it off
Old May 15th, 2011, 08:27 PM   #6
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
Ward told me about this but i just couldn't beleive it wow never thought you'd let that body go
HPandThrottle is offline   Reply With Quote
Old May 15th, 2011, 08:39 PM   #7
kickstand
circling the drain
kickstand's Avatar
I agree, keep the 79 cab, that truck looks great. The older cab is cool, but not cool enough to pull the 79cab off
Old May 15th, 2011, 08:58 PM   #8
IDIeselman
IDIeselman's Avatar
Thanks guys. I'm not letting the 79 cab go, I have had it 15 years and hope to have it another 15 but, It's not nearly as nice as I keep it touched up to appear. I'll replace the mounts, floor pan, corners and repaint when it's off but there is just something about that 40 ford cab I fell in love with and when you are running against 2500LB Jeeps with a 4000 LB truck you tend to get your ass kicked more often than not
Old May 15th, 2011, 09:07 PM   #9
boggin-machine
what are you going to do with the old cab then?
Old May 16th, 2011, 09:37 AM   #10
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Tim, Please pull a measurement on the frame you are mocking with. The f250 frames are a different width than the f150/bronco frames in front. Just dont want you to get screwed. Other than that looks great. Where is the cab at?
Old June 11th, 2011, 06:25 PM   #11
IDIeselman
IDIeselman's Avatar
Thanks Collin, The cab is at a top secret location in Silver lake. The front mounts are 32" the same as the bronco frame. Some progress has been made with new rockers, cab corners, door lowers, front mounts with reinforcements, floorpan and bear claw latches to keep the doors closed tight.
Name:	40 ford 006.jpg
ID:	79933   Click image for larger version
Name:	40 ford 002.jpg
ID:	79934   Click image for larger version
Name:	40 ford 003.jpg
ID:	79935   Click image for larger version
Name:	40 ford 004.jpg
ID:	79936   Click image for larger version
Name:	40 ford 001.jpg
Old June 15th, 2011, 12:49 PM   #12
dirty addiction
dirty addiction's Avatar
looking good old schools rule
dirty addiction is offline   Reply With Quote
Old August 14th, 2011, 10:14 AM   #13
IDIeselman
IDIeselman's Avatar
Ouch! This hurts more than I thought it would. The 79 cab has gone down hill fast as is now going to the crusher, Feels like losing an old friend. Getting ready for the 40 now so in a couple weeks I should be feeling a little better about my loss.
ID:	82381   Click image for larger version
Old August 14th, 2011, 10:19 AM   #14
boggin-machine
whys the cab going to be made into pop cans? what happened?
Old August 14th, 2011, 11:47 AM   #15
Fullsize4life
Kicking Cancers ASS
I take it the floor was a lot worse than what it looked? I know you had said the rear of the cab was starting to separate.
Old August 14th, 2011, 11:11 PM   #16
IDIeselman
IDIeselman's Avatar
No pop cans for this one. It will be going back to the ground. It was bad Collin, No rear support structure or cab mounts left. We mounted mock the 40 cab today and that made me feel a little better.
Name:	40 ford#2.jpg
ID:	82408   Click image for larger version
Name:	40 ford#3.jpg
Old August 14th, 2011, 11:19 PM   #17
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Just saw this:
If its anything like the 79 was when I first saw it, ..............I'm already drooling.
Old August 30th, 2011, 12:25 PM   #18
dirty addiction
looking good whens it going to be out this season yet??
Old August 30th, 2011, 02:30 PM   #19
Fullsize4life
Kicking Cancers ASS
I talked to your old man yesterday and he said it was coming along nice. I here he may have one also?
Old September 30th, 2011, 11:08 PM   #20
IDIeselman
IDIeselman's Avatar
It's coming along real nice, Just a few things to do yet and then it comes back off for final prep work and paint. Pops already has another 40 all blasted and ready for new metal but, He is working on making his starliner road worthy. Mine won't be out this season, Schuss climb will most likely be the first run for it.
Name:	1940 fordx4 002.jpg
ID:	84036   Click image for larger version
Name:	1940 fordx4 005.jpg
ID:	84037   Click image for larger version
Name:	1940 fordx4 009.jpg
ID:	84038   Click image for larger version
Name:	1940 fordx4 010.jpg
Page generated in 0.42726 seconds with 84 queries
