2003 7.3L powerstroke...cranks, won't run - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2011, 09:38 PM   #1
chris1044
chris1044's Avatar
Default 2003 7.3L powerstroke...cranks, won't run
Not my truck...don't do much diesel work and I don't have mech's for the truck/a scan tool.
Guy was driving down the road, hit a bump, truck would then only idle and the Overdrive "OFF" light along with the "wait to start" light came on in the dash. Gas pedal did nothing at this time, but he pushed the OD button on the shift lever and everything started acting OK again.
Later in the day, same thing happened, but it died a few seconds after and hasn't restarted since.
Checked the crank/cam position sensor, not bad. Checked oil, it's full, checked the high pressure oil pump reservoir, it's full as well. Checked for fuel in the fuel filter housing, it's there and flows without bubbles with the key on/engine off.
What's next??? I'm not a powersmoke guy, and I'm fighting with my hand tied behind my back without any diag info/scan tool.
Old May 15th, 2011, 10:02 AM   #2
frdboy
frdboy's Avatar
Do you get a check engine light on when you turn the key on? If not check fuses, esp. the pcm fuse. It powers a heater in the fuel filter that shorts out and takes out that fuse. There also is a battery connection under the air filter in a red box, sometimes those corode and break.
Old May 15th, 2011, 11:10 AM   #3
Toivo
Feel lucky?
Toivo's Avatar
the O/D switch can cause some fucky issues. I don't know jack about automatics tho, head over to thedieselstop or powerstroke.org
Old May 15th, 2011, 08:43 PM   #4
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
I knew someone that had the injector module got bad and it wouldn't run but never had any of the other issues that your having.
ATOMIC_BADBOY is offline   Reply With Quote
Old May 17th, 2011, 07:48 PM   #5
chris1044
chris1044's Avatar
Rumor has it that the injection drive module went bad...they ended up taking it in. We'll see if that fixes it.
Old May 21st, 2011, 10:19 PM   #6
88fordman
88fordman's Avatar
IDM ahhh! BIG $
88fordman is offline   Reply With Quote
Page generated in 0.27868 seconds with 41 queries
