Dana 44 front**REMOVE** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2011, 10:05 PM   #1
pigfat
GONE COMMANDO
pigfat's Avatar
Default Dana 44 front**REMOVE**
Im looking for a dana 44 front with a driver side drop, low pinion. Really only need the housing but will consider the whole axle.
pigfat is offline   Reply With Quote
Old May 13th, 2011, 07:02 AM   #2
mtheaded
i have one with 4.10 gears from a J10.
mtheaded is offline   Reply With Quote
Old May 14th, 2011, 11:15 PM   #3
pigfat
GONE COMMANDO
pigfat's Avatar
p.m. sent
Old May 15th, 2011, 09:03 AM   #4
TurdBronco
what width are you looking for?
Old May 15th, 2011, 12:55 PM   #5
shredder70
Chillin with the top off.
shredder70's Avatar
I have a hp out of a 79 ford f250.
shredder70 is offline   Reply With Quote
Old May 15th, 2011, 01:17 PM   #6
pigfat
GONE COMMANDO
pigfat's Avatar
J10 length would be good but i can cut some length out as i will be flipping it and running it as a high pinion on the passenger side.
Old May 15th, 2011, 01:18 PM   #7
pigfat
GONE COMMANDO
pigfat's Avatar
wont work for me i have a passenger side drop and im trying to make a high pinion passenger side drop.
Old May 15th, 2011, 01:33 PM   #8
Iwannabeoffroad
Iwannabeoffroad's Avatar
I have an 8 lug model out of a 70's chevy 3/4 ton..with 410 gears...I am going to use the brakes from it and might take the ring and pinion...the housing will be cheap!
Iwannabeoffroad is offline   Reply With Quote
Old May 15th, 2011, 01:53 PM   #9
TurdBronco
what is j10 width? I have a fullsize ford cut down about 3". Its about 63" wide from wms~wms.
Old May 15th, 2011, 02:02 PM   #10
BIGBEN
All out Idiot
BIGBEN's Avatar
you can't flip a low pinion upside down to get a high pinion unless you want it to spin backwards.
BIGBEN is offline   Reply With Quote
Old May 15th, 2011, 02:11 PM   #11
pigfat
GONE COMMANDO
pigfat's Avatar
reverse rotation ring and pinion
Old May 15th, 2011, 03:12 PM   #12
TurdBronco
If mine will work for ya, 40 bucks for the housing.
Old May 15th, 2011, 03:14 PM   #13
pigfat
GONE COMMANDO
pigfat's Avatar
ill go measure it. Where is it cut down? in the middle of the tubing or were the knuckle ends taken off and cut from the end?
Old May 15th, 2011, 03:29 PM   #14
TurdBronco
end
Old May 15th, 2011, 08:04 PM   #15
BIGBEN
All out Idiot
BIGBEN's Avatar
it doesn't work that way. a high pinion is a high pinion from the start. special housing and special gears.
you can't put high pinion gears into a low pinion housing.
and there is no such thing as reverse rotation gears.
Old May 15th, 2011, 08:08 PM   #16
pigfat
GONE COMMANDO
pigfat's Avatar
seriously?
http://cgi.ebay.com/ebaymotors/DANA-...Q5fAccessories
Old May 15th, 2011, 08:08 PM   #17
BIGBEN
All out Idiot
BIGBEN's Avatar
please read all the info in this link and learn all you want to know about dana 44s
---clicky me for d44 info---
Old May 15th, 2011, 08:13 PM   #18
pigfat
GONE COMMANDO
pigfat's Avatar
I understand how it works. If i place the pinion on the other side of the ring gear the axle will now drive in reverse. But if i swap that gear out with a reverse cut gear, which means the helix of the gears now flow the opposite way. The axle will drive forward. Hence reverse cut gear.
Old May 15th, 2011, 08:17 PM   #19
BIGBEN
All out Idiot
BIGBEN's Avatar
whatever. buy your parts. try and make it all fit.
and when it doesn't work, you don't need to apologize to me because you are wrong.
i am just trying to save you time and money, but you don't have to listen to me.
Old May 15th, 2011, 08:17 PM   #20
pigfat
GONE COMMANDO
pigfat's Avatar
yes, and the article confirms what i say. Thanks though i did know about that.
Page generated in 0.34046 seconds with 83 queries
