Auxilary Fuel Tanks? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2011, 06:39 AM   #1
ckhanna71
ckhanna71's Avatar
Default Auxilary Fuel Tanks?
Has anyone added a auxilary fuel tank on a 3/4ton diesel truck? Did you tee off right into the fuel sytem of the truck or do you use an external pump?
ckhanna71 is offline   Reply With Quote
Old May 12th, 2011, 05:43 PM   #2
dzltech
I intalled them on Superduty diesels but they use a frame mounted high pressure pump instead of a in tank pump. With the Superduty I just use a electric 6 port valve between the pump and the tanks and let the in bed tank gravity feed into the pump, works great.
dzltech is offline   Reply With Quote
Old May 12th, 2011, 05:55 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
I do them a lot. It's a gravity feed set up that tee's into your filler hose. Turn the valve on the tank on and it fills your main tank, no spillover either with the check valve in the filler T. Never need to open your main tank again just fill the aux.
Old May 13th, 2011, 06:18 AM   #4
ckhanna71
ckhanna71's Avatar
I can't wait to get a tank, tired of trying to find gas stations with diesel when pulling the 5th wheel.
Page generated in 0.25542 seconds with 35 queries
