94 F150 4x4 jerking - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2011, 12:03 AM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 94 F150 4x4 jerking
Looking at buying a nice 94 extended cab 4x4 f150, but I noticed that the front end jerks pretty bad when making tight turns even when the 4x4 is NOT engaged. Any idea what would cause this?
chevyk10 is offline   Reply With Quote
Old May 11th, 2011, 12:16 AM   #2
mudrunner78
mudrunner78's Avatar
Hubs are staying engauged
mudrunner78 is offline   Reply With Quote
Old May 11th, 2011, 06:27 AM   #3
chevyk10
FORD / GM
chevyk10's Avatar
What would cause that and how could you fix it? It has automatic locking hubs. This would be my first 4x4 so I don't know too much about them.
Old May 11th, 2011, 08:55 AM   #4
Quiefinator
go'til itsounds expensive
Buy manual lockouts and throw those automatics in the garbage. my .02
Old May 11th, 2011, 09:02 AM   #5
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
Might want to check the Trailing arm bushings at the bracket near the frame, or check to see if the trailing arm is rotted out on the bottom side next to the torsion beam.
Old May 11th, 2011, 04:59 PM   #6
chevyk10
FORD / GM
chevyk10's Avatar
Ok thanks I'll check it out. The truck only has 105k miles and was driven only buy 2 older guys so its in damn good shape. Not much rust on the underside either so I'm gussing the hubs are just crap.
Old May 11th, 2011, 11:07 PM   #7
Daddy Dan
SBF Nut
Daddy Dan's Avatar
My 2wd just had the eccentric ring in the radius arm bushing break. Its a 2wd and does this. Plus, those bushings could easily be rotted out by now. Or, automatic hubs are known to seize or break.
How many F150s have you had now?
Daddy Dan is offline   Reply With Quote
Old May 11th, 2011, 11:12 PM   #8
chevyk10
FORD / GM
chevyk10's Avatar
We found out the linkage is messed up for the floor shifter and it was in 4wd the whole time even though it was set to 2wd lol. Easy fix. And at least 10. Can't pass up a great deal like this though. 4x4 ext cab 351 with 105k miles and very little rust for $1,500.
Page generated in 0.22161 seconds with 47 queries
