GOT ONE = Pass. side hi steer arm hp d44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 10th, 2011, 02:57 PM   #1
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Default GOT ONE = Pass. side hi steer arm hp d44
My steering radius kinda blows with the ford knuckle, so I think I need to put a hi steer arm on to be able to turn around in less than a 10 acre field.
Let me know what you have.
thanks
RIP FULLSIZE4LIFE
Old May 10th, 2011, 03:05 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
i built mine and they turned out really nice. i just used a grinder, porta band and a drill press. took probably 2 hours.
Old May 11th, 2011, 09:32 AM   #3
SHARPMACHINE
F-U-CANCER!!!
Not a bad plan, what material should I use???
I would prefer to make my own, except it is sometimes hard to find the time.
RIP FULLSIZE4LIFE
Old May 11th, 2011, 09:38 AM   #4
chadcooper55
i had a chunk of 7/8" plate that i used. i sprayed the steel with primer so i could scribe all the lines on it instead of writing with soap stone. i cut the radius around the ball joint with a 2 1/8" hole saw and the 3 holes for the bolts i drilled bolt size for a snug fit. if you take your time with the layout they are easy to build. i think i have some pics, i will look and post them up.
Old May 12th, 2011, 12:17 AM   #5
chadcooper55
my knuckle was drilled and tapped by the previous owner so none of my measurements will work for you. it is too bad because laying it out is the hardest part.
Old May 16th, 2011, 11:22 AM   #6
SHARPMACHINE
F-U-CANCER!!!
Thanks Chad. If I get time or don't find a good deal I'll make one.
RIP FULLSIZE4LIFE
Old June 13th, 2011, 07:56 AM   #7
SHARPMACHINE
F-U-CANCER!!!
Semi trucks make tighter turns than my jEeP.
RIP FULLSIZE4LIFE
Old September 12th, 2011, 12:52 PM   #8
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Mad 4x4 $79. Pretty hard to make it yourself for that kind of money....
Old September 12th, 2011, 01:24 PM   #9
1989gmc
1989gmc's Avatar
http://cgi.ebay.com/ebaymotors/CNC-m...item3a678047fe
$39.95 free shipping...
1989gmc is offline   Reply With Quote
Old September 12th, 2011, 01:47 PM   #10
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Originally Posted by 1989gmc View Post
win!!!!
Old September 12th, 2011, 04:53 PM   #11
1989gmc
1989gmc's Avatar
Originally Posted by SANDVIPR View Post
win!!!!
Old May 31st, 2012, 08:45 AM   #12
SHARPMACHINE
F-U-CANCER!!!
^ Yes, I think I should order one of these, to bad someone going to 1 tons don't have one to sell though?
RIP FULLSIZE4LIFE
Old June 8th, 2012, 10:11 PM   #13
nvr-enuf-money
Old Hippie
nvr-enuf-money's Avatar
got one 75.00 never used good for high steer and crossover steering Brian 517-202-3175
nvr-enuf-money is offline   Reply With Quote
Old June 12th, 2012, 03:15 PM   #14
SHARPMACHINE
F-U-CANCER!!!
Are you sure you can't beat the price of the one I can order on e-bay = 75. shipped with studs and conical washers etc..???
RIP FULLSIZE4LIFE
Old June 13th, 2012, 08:18 AM   #15
nvr-enuf-money
Old Hippie
60.00 with studs and washers 517-202-3175
Old June 15th, 2012, 04:24 PM   #16
SHARPMACHINE
F-U-CANCER!!!
I called about this. His has a # HSP613-3 on it. It has the holes for a reid racing spindle in it. I need to confirm if it will fit my hp d44??
Thanks Brian!
IDK I have never done hi-steerering stuff.......
RIP FULLSIZE4LIFE
Old July 2nd, 2012, 08:28 AM   #17
SHARPMACHINE
F-U-CANCER!!!
Bring me a hi-steer arm on your way to the dunes. It will cover some of your beer money....
RIP FULLSIZE4LIFE
Old August 9th, 2012, 08:13 AM   #18
SHARPMACHINE
F-U-CANCER!!!
Where is a good place to get just the studs, or could grade 8 threaded rod be used??
Other offers??
RIP FULLSIZE4LIFE
Old August 10th, 2012, 04:38 PM   #19
cannaert
No more Jeep
cannaert's Avatar
I got my arm off ebay as a blem, paid 40 fir it shipped. Then I picked up a 3 foot stick of hardened threaded rod and lock nuts, plus new Conical washers from the a GM dealer.
I was under 60 bucks for it all
Old August 10th, 2012, 04:40 PM   #20
cannaert
No more Jeep
cannaert's Avatar
Forgot I that I also have the a tap as well for a 20 more, but 80 for it all was a lot better than 80 just for the arm.
Page generated in 0.61928 seconds with 83 queries
