Axle measurements, bent tubes? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 9th, 2011, 04:54 PM   #1
upchuck
upchuck's Avatar
Default Axle measurements, bent tubes?
What's the foolproof way of determining if my 8.8 is bent?
Shafts do not seat without heavy hits with a mallet, well the left that is. Pass side not cooperating at all.
upchuck is offline   Reply With Quote
Old May 9th, 2011, 05:36 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I have a digital level we can check it with, I looked at it with the dial type I had and it looked good. If it is bent I can help you with it. Give me a call.
Old May 10th, 2011, 08:26 AM   #3
There's a simple method by taking the guts out of the axle, and putting a light at the end of one tube. When you look through the other side, then you should see circles at the bearing end of each axle tube, and for the bearing caps. All 4 bearing circles should be concentric if the axle is straight.
Old May 10th, 2011, 08:30 AM   #4
curbdog17
Mini Van
curbdog17's Avatar
Nice tip, I will remember that
Old May 10th, 2011, 04:02 PM   #5
upchuck
upchuck's Avatar
This seems to confirm my suspicion. Getting concentric reflections off the splines of the side gears, the opposite bearing is forward.
Old May 10th, 2011, 04:43 PM   #6
Here's a little article/visual
http://www.performanceunlimited.com/...traighten.html
Page generated in 0.33773 seconds with 41 queries
