Wanted Jeep CJ Dana 44. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2011, 10:50 PM   #1
coteys
Stu
coteys's Avatar
Default Wanted Jeep CJ Dana 44.
Anyone have a complete Rear Dana 44 with a centered diff from a Jeep CJ?
I would like it for my CJ5 project.
Thank's.
coteys is offline   Reply With Quote
Old May 7th, 2011, 12:34 PM   #2
mtheaded
I have one with 4.88 gears and SSBC disc conversion (almost $800 by itself).
mtheaded is offline   Reply With Quote
Old May 10th, 2011, 11:02 AM   #3
coteys
Stu
coteys's Avatar
Default Dana 44 with SSBC Brakes
How much would you want for it?
Let me know.
Thanks
Old May 10th, 2011, 11:14 AM   #4
orionn
orionn's Avatar
Do you want a Narrow trac or a Wide trac?
orionn is offline   Reply With Quote
Old May 10th, 2011, 12:04 PM   #5
coteys
Stu
coteys's Avatar
Default Dana 44
I have NT now, but either will work. I will chang the dana 30 to match, spacers or whole axle). I am more concerned with the gearing and price.
I have 4.10 gears now. So either I need that ratio or will need to do a gear swap.
Old May 10th, 2011, 01:01 PM   #6
orionn
orionn's Avatar
Let me look at what I have. I have a NT Rear D44 from a Jeepster Commando but I dont know what gears are in it, or its condition. It would be direct bolt in for you.
Old May 10th, 2011, 01:04 PM   #7
bigredjeep1
I have a pair of Scout dana 44s for sale in Roscoe, IL 61073
Stock 3.07 gears open carriers
$400 OBO for the pair
Troy 815 222 9409 text
bigredjeep1 is offline   Reply With Quote
Old May 10th, 2011, 02:55 PM   #8
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
QUOTE=mtheaded;2649687]I have one with 4.88 gears and SSBC disc conversion (almost $800 by itself).[/QUOTE]
Assuming this is a wide-track axle, it would be a VERY nice option.
4.10 wasn't a stock gear used in the D44s, to the best of my knowledge. You'll commonly see 2.73, 3.54 or 3.73 depending on the year. Wide-track was only used in '86. The price is likely to be exponentially higher for a WT vs. a NT Dana 44.
This is a very nice option. We used a '72-73 Commando axle with spacers to match a wide-track front in a charity/raffle Scrambler we built for the Scrambler Owners Association. It was a very nice set-up.
Craig
Old May 10th, 2011, 03:52 PM   #9
dmcjeep
dmcjeep's Avatar
Hey Craig hows it going? I believe that the early dana 44 narrow tracks from the 72-75 CJ's had a few that came with 4:10 gears.
dmcjeep is offline   Reply With Quote
Old May 13th, 2011, 11:41 AM   #10
orionn
orionn's Avatar
Originally Posted by dmcjeep View Post
...I believe that the early dana 44 narrow tracks from the 72-75 CJ's had a few that came with 4:10 gears.
Yes, but they were all offset diffs becouse of the D18 t-case, not centered.
Only the 66-73 Jeepster Commando's got the centered diff NT D44's iirc.
One of the things that makes these axles desireable is they came with several different ratios available from the factory from 3.31:1 down to 5.38:1 if you bought the optional gear package.
My own Jeepster Commando ('71) has 4.27:1 gears from the factory in it, my other has 3.73:1 gears which seems to be the most common ones you will find.
The CJ5 crowd loves getting ahold of the Jeepster Commando axle. and they can cost some serious cash for them.
THe rear axle i have is not complete, it would need to be gone thrue.
I could not get to it, I'll pull it out tommarow and see exactly what it needs.
Old May 13th, 2011, 11:53 AM   #11
Bo's Cj 7
Bo's Cj 7's Avatar
72\\\\\\\\\\' dana 44 from mail/gov jeep - Great Lakes 4x4. The largest offroad forum in the Midwest
Bo's Cj 7 is offline   Reply With Quote
Old May 13th, 2011, 11:54 AM   #12
1x1_Speed_Craig
Simplify...
Intermediate CJ-5s ('72-'75) had centered Dana 44s, too. They're just not a bolt-in for a later-model CJ.
Craig
Old May 13th, 2011, 01:14 PM   #13
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Axle perches are cake, in the grand scheme of things.
Old May 13th, 2011, 01:49 PM   #14
dmcjeep
dmcjeep's Avatar
Craig
Craig is correct here and I do believe that some of these had 4:10 gears from the factory.
Page generated in 0.43346 seconds with 66 queries
