looking for 8.8-9" ford rear end - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2011, 08:00 AM   #1
95beast
Im Farva Bitches
95beast's Avatar
Default looking for 8.8-9" ford rear end
I need a ford fullsize rear end either a 8.8 -9" That is 55"s from back plate to back plate.... Take some measurments ang let me know what you have
The rearend is going in a 64 ford pickup it doesnt matter gears or anything as long as its 55"s Thanks
95beast is offline   Reply With Quote
Old May 7th, 2011, 02:57 AM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Does back plate to back plate for you mean the same as WMS to WMS to everyone else? Or are you actually looking for an axle based on where the brake backing plate is?
FYI - Most full-size rear axles are in the neighborhood of 65" between the wheel mounting surface.
Ranger Based vehicle (RBV) rear axles are in the 56.5-60.5" range depending on year.
If you're interested I have a 94 explorer axle(60.5 wide) with 3.27 gears, welded carrier, spare carrier(no spiders) and new drum brake shoes and hardware. I would like $200 for it. I also have a set of 3.73 gears that could go with it.
Old May 8th, 2011, 11:54 PM   #3
95beast
Im Farva Bitches
95beast's Avatar
yea he said 55" from the back of each backing plate.. its not for me its for a friend and thats all that he told me but im guessing he wants it the 5x5.5 bolt pattern thanks though.... ill prob run to the jy and look around..
Old May 9th, 2011, 09:11 AM   #4
Quiefinator
go'til itsounds expensive
I got one bolted up to a 1966 F-100, should be just what you need. I also have a ton of others parts for those trucks. LMK
Old May 9th, 2011, 05:13 PM   #5
Zebrafive
Measured the Bronco, 58" brake plate to brake plate.
Zebrafive is offline   Reply With Quote
Old May 9th, 2011, 10:50 PM   #6
blown altered
gotsand
blown altered's Avatar
i have 8.8 from a 88 95 and 96 bronco 150.00 complete
blown altered is offline   Reply With Quote
Old May 9th, 2011, 10:54 PM   #7
95beast
Im Farva Bitches
95beast's Avatar
is it 55" ?
Page generated in 0.29003 seconds with 44 queries
