Pretty much fucked, need some advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2011, 04:10 PM   #1
Marine_mike
SNSHTF
Marine_mike's Avatar
Default Pretty much fucked, need some advice
So it's become obvious that I have poor judgement these days. I traded a perfectly running and built YJ for what seemed to be a lifted and well running ZJ. Welp....2 weeks after I got it, the trans died. Then I discovered some really rotten rockers. And today, the bugger welded lower control arm bracket on the pass side ripped off the axle tube. Now, my question is should I replace the lower control arm bracket (which will most likely require both sides to be done) or try and find a replacement axle? Keep in mind, like most, I am broke as hell and this is my only vehicle for getting to work and driving my kids around.
Click this link ---> http://www.gunwatcher.com/c/5751 is having a HUGE giveaway at the end of December 2014!
Marine_mike is offline   Reply With Quote
Old May 5th, 2011, 04:29 PM   #2
Disturban
Disturban's Avatar
If you know how to weld I would just weld it back on...if you dont know how to weld have someone who does weld it back on, I would also check the other side...I would probably cut the other side off and clean them both up and bevel the edges and weld them both on at the same time. If one broke do you trust the other?
Also don't forget to make a post in the pub about how nobody should do business with the guy you got it from because he traded you a piece of shit and got your good jeep with nothing wrong with it...that seems to be the normal thing to do on the forum
Old May 5th, 2011, 04:29 PM   #3
MiNi Beast
MiNi Beast's Avatar
just have some 1/4" brackets welded on and be done with it. Be cheaper then sourcing a axle and swapping it in.
Old May 5th, 2011, 04:40 PM   #4
Marine_mike
SNSHTF
I'm not gonna flame the guy because I'm an idiot for trusting someone and not inspecting it properly. The bracket in question is trashed. There's no saving it. I'll have to try and get some money from somewhere and order the 1/4" ones from rusty's. Until then, I'm without a vehicle.
Old May 5th, 2011, 05:44 PM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
dont bevel the edges as stated above just butt them up to the tube and weld them. with a fillet weld you just need your weld to be as thick as the thinnest part that you are welding to.
Page generated in 0.16682 seconds with 38 queries
