Project: Pavement Sucks in a zj - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2011, 07:52 PM   #41
Shotgun
I only wheel with boats.
Shotgun's Avatar
Looks like shit, come help fix my junk!
Old November 3rd, 2011, 09:01 PM   #42
GREASYHANDS
GREASYHANDS's Avatar
what did you break now? Or do you need help welding a pully to your crankshaft
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 26th, 2011, 02:38 PM   #43
GREASYHANDS
Just ordered a set of H.D. Offroad shackle relocation brackets.
http://www.naxja.org/forum/showthread.php?t=1065577
I also have a set of teraflex 1.5" replacement shackles that I will be installing when I get my brackets.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 26th, 2011, 06:03 PM   #44
motox168
Bare Bones Offroad
motox168's Avatar
Actualy I think I have your shackles, did i miss what you said you were doing with the front?
motox168 is offline   Reply With Quote
Old November 26th, 2011, 06:29 PM   #45
GREASYHANDS
The front is going to stay the same for now. I am trying to combat some of the leaf sag and harsh ride I have with the Rough Country spring packs. Hopefully I wont gain much lift with both these setups. maybe about 2 inchs.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 26th, 2011, 07:55 PM   #46
Moles
..are slippery
Moles's Avatar
Originally Posted by GREASYHANDS View Post
I think Im spending more money on the maintenace of this thing than I have building it. Few weeks ago I replaced a front hub unit, monday I found a broken motor mount and had to repair that aswell. However I have found a set of 5 rubicon wheels thanks to Moles. I want to put a set of 285/75/16 coopers on them. I mocked one wheel and tire on the jeep, all of my control arms, springs, and steering all clear! Now time to find a set of tires.
Those rims look good on there. A lot better than sitting in a pile!
Moles is offline   Reply With Quote
Old November 26th, 2011, 08:02 PM   #47
GREASYHANDS
Thanks. Im still looking for a set of tires to put on them. I mounted 4 285/75/16 BFGs on them for now. It handles much better on the road now, and I like the way they look
I found a set of yj flairs chillin in my rafters. Did some cutting and came out with this.
Opinions?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 26th, 2011, 08:21 PM   #48
jbsjunk
Little Member
jbsjunk's Avatar
A bit wider than the stockers. Looks good. My only meh is the back end.
Old November 27th, 2011, 12:43 AM   #49
GREASYHANDS
Yeah the back side could use some work, as luck has it I have 3 more I can hack up.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 27th, 2011, 06:23 AM   #50
curbdog17
Mini Van
curbdog17's Avatar
lookin good Scott.
Old November 27th, 2011, 09:57 AM   #51
creeping death
I'm that guy.
creeping death's Avatar
Opinions?
the rims look sweet on there. the flairs not so much.
Old November 27th, 2011, 11:55 AM   #52
motox168
Bare Bones Offroad
motox168's Avatar
x2
Old November 27th, 2011, 03:13 PM   #53
kmanxj5011
kmanxj5011's Avatar
Did you just cut the rear out? No fold? Just looks like to Sharp of an edge to be folded?
kmanxj5011 is offline   Reply With Quote
Old November 27th, 2011, 04:35 PM   #54
puckett
puckett's Avatar
dont be cutting up all those flares, im interested in a front set!
puckett is offline   Reply With Quote
Old November 27th, 2011, 05:52 PM   #55
GREASYHANDS
Yes the PO did the body cutting there is no fold on the rear. I was entertaining the idea of some colored rivets to hold the panels back together in the rear.
No worries the fronts are yours, I have those 2 and 4 rears, two of the rears are still uncut.
I have decided against the flares for the moment. If I recall I tried the same thing a few yrs back and didnt like it then. Thats why I happened to find these sitting in the rafters covered in dust.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 27th, 2011, 08:22 PM   #56
kmanxj5011
kmanxj5011's Avatar
I see. One of my buddies has the same issue except cut higher and the whole rear rocker was cut off instead of folded.
Old December 6th, 2011, 06:07 PM   #57
GREASYHANDS
Do the rear quarters flop in the wind?
So I have been slowly picking away at the rear of my jeep. I started to prep the back side for the install of my new shackle relocation boxs. The bumper came off sunday afternoon, and today I tackled the Hidden Hitch. It took a bit of heat to get the nuts to come off the nut strip but every one came off. The worst part was the washers had rusted onto the studs holding it in place.
I cut a small hole in between the bumper mounts to access the welded nut that secures the upper shackle bolt. I had been spraying this nut with penetrating oil since the bumper came off. 3ft breaker bar and the bolts both broke free with ease. Now I need to find some down time and actully tear it all apart.
I found a factory gas tank skid laying in my parts pile also. Prolly gonna sandwich that thing up there too. The only thing keeping me from putting it on before is because I never wanted to pull my hitch down. So I guess now is the time to do it.
I got a coat of prime on the brackets monday. What color should I paint them? I have a good quart of Rustolem paint, color : Aluminum. But I was thinking about not using it.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 6th, 2011, 06:33 PM   #58
jbsjunk
Little Member
jbsjunk's Avatar
Could steal some of Mini's pink paint.
Old December 6th, 2011, 06:57 PM   #59
GREASYHANDS
I am not going to be painting the underside of this pink! I think Curbdog could you some more pink paint though. It will match his pretty pink fan.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 6th, 2011, 07:04 PM   #60
jbsjunk
Little Member
jbsjunk's Avatar
True dat. Steal Mr. Happy back from Creepy and complete the circle.
Tags
meballs, meow, wind chimes
Page generated in 0.54775 seconds with 84 queries
