Timing a 400 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2011, 12:39 PM   #1
79f150
Mud Digger
79f150's Avatar
Default Timing a 400
I was at a bogg and old distributer took a poop went and got a new one and put motor at tdc and put the new one in and pointed rotor at 1 on cap but cant get timing even close
79f150 is offline   Reply With Quote
Old May 3rd, 2011, 03:03 PM   #2
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Last edited by BigBird; May 3rd, 2011 at 03:04 PM. Reason: oops 400 FORD in ford tech, not CHEVY TECH... my bad
Old May 3rd, 2011, 11:17 PM   #3
79f150
Mud Digger
79f150's Avatar
Old May 4th, 2011, 01:00 AM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
You are at TDC on the compression stroke, right? If so, you should be within a few degrees, at least close enough to have the engine run rough. Just to be clear though, you have the rotor pointed at the terminal that has the wire for plug #1 on it not the spot on the cap that has the #1 cast into it. Also, cylinder #1 on a Ford is the passenger front, opposite of chevy in case you're used to working on those.
Old May 5th, 2011, 11:10 PM   #5
79f150
Mud Digger
79f150's Avatar
my timin chain jumped....... i knew i was doin it right..... thanks for the tips BigBlock
Old May 11th, 2011, 12:00 PM   #6
ultimatehellhound
Sounds like it's time to swap a 460 in it.
ultimatehellhound is offline   Reply With Quote
Page generated in 0.24421 seconds with 41 queries
