dodge lift question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 2nd, 2011, 08:17 PM   #1
billycole
Default dodge lift question
Will a 3" lift on a 2001 dodge ram extended cab cause any drive line issues? Drive shaft vibrations or anything? Will it clear 33x12.5s on 10" wide rims?
billycole is offline   Reply With Quote
Old May 2nd, 2011, 08:25 PM   #2
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I have just leveling springs on the front of my 3/4 ton and i run 35's on 9" wheels.
sbcrichie is offline   Reply With Quote
Old May 6th, 2011, 09:21 PM   #3
billycole
What is the normal lift block thickness on the back of a stock 2001 half ton?
Old May 8th, 2011, 08:53 AM   #4
Flat_Black
The Dodge Guy
Flat_Black's Avatar
2" if i rememeber right.
Old May 8th, 2011, 02:18 PM   #5
lauriat
lauriat's Avatar
With a 3/4 ram you can get up to either 8 or 9 inches of lift before you have to worry about your driveshafts.
I have a 2 1/2" leveling spacer on my 01 cummins with 315 Mickey Thompsons on 3rd gen aluminum wheels with no issues. I also had a 99 ram 1500 sport with 3" BL and 3" spacer running 35x12.5's with lots of room left.
lauriat is offline   Reply With Quote
Old May 8th, 2011, 02:30 PM   #6
curbdog17
Mini Van
curbdog17's Avatar
I lifted my 2003 1500 ram with a leveling kit and ran 35 12.50 17's procomp all terrains on stock wheels with out any rubbing.
Old May 8th, 2011, 05:03 PM   #7
billycole
I am trying to figure out if the 2001 dodge I just got has some kind of lift in it. It seems like it kind of sits high compared to most. There is no leveling kit, The block under the leafs is 3"s and there are 5 leaf springs in the pack. I want to lift it to fit some 33 by 12.5 on 10 inch rims. Currently it has 285-75-16's on stock rims with no clearance issues at all.
Old May 10th, 2011, 07:34 PM   #8
mj23polaris
mj23polaris's Avatar
off road edition?
mj23polaris is offline   Reply With Quote
Old May 15th, 2011, 01:30 PM   #9
SizeMatters
Sketchy, Son....
SizeMatters's Avatar
The 285s are 33s(32.8) and 11" wide. So yes im sure that you could stuff 33x12.50s on it.
SizeMatters is offline   Reply With Quote
Old May 18th, 2011, 10:24 PM   #10
COWWBOY
I have a 98 1500 quad cab sport with 285 75 16 stock rims on it the only rubbing is when the wheel is cut hard either direction. With the right backspace you should fit thoes no problem stock.
COWWBOY is offline   Reply With Quote
Old June 5th, 2011, 08:14 AM   #11
PavementPounder
PavementPounder's Avatar
If you have the Off-Road Edition and already have 285's on it, there is no need to do anything to the truck to fit 33's. Go find a tire size calculator online, convert the 285 size from metric to imperial and you will see why.
Don't bother with the 10" rims. You can safely run a 12.5" tire on a 7" rim. Your factory rims will be fine. A 10" rim on a 12.5" tire will push the sidewalls out and weaken the bead. The 10" rims most likely have less backspacing (like most aftermarket rims), which could actually cause you to have interference issues with the inner fenders if the wheels are set out too far.
Page generated in 0.26043 seconds with 56 queries
