Towing with a motorhome, what should I look for before I buy? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2011, 12:45 PM   #21
Tab
Tab's Avatar
I believe it was in 01 that the chevy chassis went wider. I had a 2000 that was narrow and we looked at some 01's and they were all wide. HUGE difference in the wind!
Old May 6th, 2011, 08:31 AM   #22
CreativeFab
used to be Ironman
CreativeFab's Avatar
I have pulled the same enclosed trailer as Jim with both a gas and diesel. The gasser was a 2000 35' Fleetwood with two slides and the V10, I beefed up the hitch and from Canada to Tn. & Pa. and all around MI it was just fine. Like Jim I would not have went out west with the enclosed behind this unit!
Now I have an 06 39' diesel pusher with a 300hp Cummins. Other than not even feeling the trailer behind it I still seem to be traveling the same up and down hills and long grades. However the diesel does it at a much lower RPM and it has the Allison 5 speed which surpasses the Ford tranny 10 fold while towing. The Cummins also has the engine brake which I didn't realize I missed until i had it. Can't tell you how many times I stood on the brakes in that Fleetwood, even with the trailer brakes set tight.
So the go is just as important as the stop! The enclosed would push the gasser, the diesel does not know it's there. 5mpg in the gas MH towing the trailer, 8 without. 8.6 in the diesel empty or towing.
Jim's advice about a shorter 30'-35' with no slides and the wide front is solid advice imo.
Old May 7th, 2011, 11:52 AM   #23
Smiley
Smiley's Avatar
Thanks Tab :)
Smiley is offline   Reply With Quote
Old July 20th, 2011, 05:50 PM   #24
Bones
Bones's Avatar
btt
I'm back into wanting a toter or motorhome. I need something that will live driving to the west coast pulling an enclosed trailer, 4200 lb buggy, tools and spare parts. That's about 9K as I have mentioned before...
Anyone know anything about a gillig chassis? It seems like this would pull all day.
http://www.rvtraderonline.com/listin...-body-98726301
Oshkosh chassis, cummins motor
http://www.rvtraderonline.com/listin...USHER-98718447
freightliner chassis, CAT motor
http://www.rvtraderonline.com/listin...winds-98917625
any new input?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 20th, 2011, 06:06 PM   #25
I don't have any experience with any diesel rigs but make sure that whatever you get, it will blend well with a light tan enclosed trailer. :)
Old July 21st, 2011, 05:33 PM   #26
Tom
Because racecar
Tom's Avatar
I don't have anything to add that has any substance that may help your decision... But I'd buy any one of those... But I not has riches so I can't buy one
Old July 21st, 2011, 06:20 PM   #27
joe_jeep
welfare wheeler
joe_jeep's Avatar
i like the looks of the gillig.
all three are respected chassis builders, any of the three would work fine.
Old July 21st, 2011, 07:17 PM   #28
Bones
Bones's Avatar
If someone would just buy my F350 I would build a toterhome....
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.29208 seconds with 47 queries
