What carb is this ? Lawnmower tech - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2011, 08:46 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default What carb is this ? Lawnmower tech
So drug the mower out the other day.. checked the oil dumped some fresh gas in the empty tank. ran great 1st pull. did a couple lines and it dies.. fuel squirting out of the primer bulb.. tapped on the bowl didn't stop.. finally it stopped messed with it some more fire back up after struggling to start. then dies again with the squirting.. it's a Craftsman mower i think 5hp the label is gone. red cover so im assuming Honda engine ? pulled the carb off the engine and pulled the float bowl.. float seems fine.. etc.. where can i get a rebuild kit for this car or possibly a new carb ?? i know VERY LITTLE about carbs.
here's a couple pics
the number on the carb is 1548b5c google turns up nothing from what i have gathered that bowl matches a tecumseh carb
Old May 1st, 2011, 08:57 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Theres not much to rebuild on those except for gaskets and stuff. Just give it a thorough cleaning with some carb and choke cleaner. Make sure all of the little ports are clean.
Old May 1st, 2011, 09:36 PM   #3
Just very carefully go through it to look for anything clogging it or varnish. In my experience, what'll happen is it'll get all varnished up, you'll clean it, then as you run fresh gas through it, more gunk loosens in the lines and you often have to clean it a 2nd time a week later. There isn't much to them.
Old May 1st, 2011, 10:43 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
so a good thorough spray with carb clean in all the orifices should tune er up ?
Old May 2nd, 2011, 06:50 AM   #5
turnofftheradio
http://outdoorpowerinfo.com/repairs/ carbs are easy as long as you can find parts. appears to be tecumseh
turnofftheradio is offline   Reply With Quote
Old May 5th, 2011, 07:46 PM   #6
SoupCan
SoupCan's Avatar
its a tecumseh, they are famous for that, your needle is stuck open.
SoupCan is offline   Reply With Quote
Old May 27th, 2011, 05:24 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
I ended up cleaning it out real good with carb clean it took a while to run on its own but it runs great on the 1st pull now
Page generated in 0.24075 seconds with 44 queries
