7/8" tap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2011, 12:45 PM   #1
MiNi Beast
MiNi Beast's Avatar
Default 7/8" tap
looking to borrow, rent or someone to tap my 1.25 dom for my chevy 1 ton tie rod ends.
thanks
Old May 1st, 2011, 02:51 PM   #2
itselliott
itselliott's Avatar
R/H or L/H ?
What thread , 9 or 14
(7/8-9 RH is a common tap)
Old May 1st, 2011, 08:36 PM   #3
MiNi Beast
MiNi Beast's Avatar
need left and right and wanna say it is 7/8 x 10 the rare tap of the 7/8ths i guess.
Old May 1st, 2011, 08:41 PM   #4
Pop-Tart
Pop-Tart's Avatar
That would be a 7/8-18.
Pop-Tart is offline   Reply With Quote
Old May 1st, 2011, 08:50 PM   #5
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
This ^
Old May 1st, 2011, 09:10 PM   #6
MiNi Beast
MiNi Beast's Avatar
thank you as I wasn't sure what it was.
Old May 1st, 2011, 09:25 PM   #7
itselliott
itselliott's Avatar
well, I have not heard of that pitch, I must have missed something.
7/8-9 is unc
7/8 -14 is unf
7/8 20 is unef
Old May 1st, 2011, 10:19 PM   #8
MiNi Beast
MiNi Beast's Avatar
7/8-9 is unc
7/8 -14 is unf
7/8 20 is unef
apparently it was to allow for more adjustments. Which is why it's a pain to find jam nuts.
Old May 2nd, 2011, 12:07 AM   #9
bigblockford79
Big Block Ranger
bigblockford79's Avatar
7/8-9 is unc
7/8 -14 is unf
7/8 20 is unef
It's a bastard thread from the bastards themselves (GM) It is used in tie rod ends for finer adjustment. They couldn't just go with 7/8-20 because that would be cheaper and make sense. 2 things that company dislikes very much.
Old May 2nd, 2011, 12:11 AM   #10
deerebowtie
Unchained
deerebowtie's Avatar
can't you get weld in bungs and jam nuts for tre's?
Old May 2nd, 2011, 05:35 AM   #11
MiNi Beast
MiNi Beast's Avatar
no that would make it illegal to drive on the road. thanks
Old May 2nd, 2011, 06:24 AM   #12
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
What is the wall thickness on your dom? If it is .250 you are going to have to have it bored out.
Old May 2nd, 2011, 01:51 PM   #13
MiNi Beast
MiNi Beast's Avatar
.25 I believe, know for sure tonight as be measuring and cutting it to length and will be having it taped tomorrow.
Old May 2nd, 2011, 02:08 PM   #14
Trail Junkie
iamfawkinwithyou
Its the same as mine roger, you have to bore it
Old May 2nd, 2011, 06:23 PM   #15
MiNi Beast
MiNi Beast's Avatar
Well I hope Sandvipr knows that then, better call him.
Old May 2nd, 2011, 06:25 PM   #16
itselliott
itselliott's Avatar
http://extremecustomparts.com/i-3615...r-weld-in.html
Found this.........
there obviously are others that share your dilema
and this:
http://www.wfoconcepts.com/pr/7-8-18...Tube/3207/3392
Old May 5th, 2011, 10:23 AM   #17
MiNi Beast
MiNi Beast's Avatar
Well Sandvipr was thinking I had 3/4 heims, so no go there, so dropped the steering off with the great guys at A&B Machine in Fruitport here. Worked with them before and they are some good guys. So dropped that off on Tues so hope to have it tomorrow. There was a question on the wall thickness being a bit small with the tie rod ends. So may cause concern perhaps. So going to wait to see when get back and then if nothing less just sleeve the tube and call it a day. Not worried about hitting it as be above the springs but the concern was in the banging and hard steering out in the ruts and rocks with the 37's. plan to is to go hydro assist later on.
Old May 12th, 2011, 08:31 PM   #18
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
I'm sure this has all been handled since (being a week old), but yes, 7/8ths-18 right and left handed taps are needed and if going with 1.250 DOM, the wall thickness should be 7/32nds to avoid needing to bore.
Nuzzy is offline   Reply With Quote
Old May 12th, 2011, 08:35 PM   #19
MiNi Beast
MiNi Beast's Avatar
yeah had to take to a machine shop, that come to find out didnt, have those taps so had to do it by point(?) and was told by guy it was a pain in the ass, and they only threaded out 2" when I needed 3" now the steel is useless, so grab an aftermarket one off another axle, and will make it work. Going to just use 1.5: and get the bungs, fuck this stupid shit.
Old May 12th, 2011, 09:04 PM   #20
RockSolid Perf.
RockSolid Performance
RockSolid Perf.'s Avatar
We have what you need,although it sounds like i'm a little late.PM me if you need some work done.
http://www.rocksolidperformance.com/..._signature.gif
www.RockSolidPerformance.com. We are dealers for AEV, Metalcloak, Motor State, Poly Performance, PSC, Yukon Gear. Like Us on Facebook.
RockSolid Perf. is offline   Reply With Quote
Page generated in 0.32226 seconds with 83 queries
