New rear bumper is finished. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2011, 01:34 AM   #1
ultimatehellhound
Default New rear bumper is finished.
I just got this finished and I'm debating on making a few more to sell. This one is 2" x 6" x 1/4" with 1" clevis tabs and 7/8" clevises. Any feedback? Are they good enough to fetch $299?
ultimatehellhound is offline   Reply With Quote
Old May 1st, 2011, 09:40 AM   #2
littletrucker
I'd hit that
littletrucker's Avatar
Looks nice but pretty plain for 299, but im not really sure how much people spend on bumpers, Id much rather build my own. Doesn't look like a lot of beef holding it to the frame
Old May 18th, 2011, 03:01 PM   #3
2fst4you
2fst4you's Avatar
add better approach angle to the ends and inforce the frame mounts a lil more then sell them!
Old May 18th, 2011, 08:06 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
yea that gusseted 1/4" plate aint gonna hold shit
Old May 18th, 2011, 08:17 PM   #5
Bones
Bones's Avatar
Actually, the way it is gusseted (ony 1/2 way down the tab), one solid pull from the D rings on a 45 degree angle will bend the mounting tabs where the tabs meet the end of the frame
The better way to gusset it would be to move the gussets to the outside part of the frame, and run the gussets the full length of the tab (from the bumper to past where it bolts to the frame. That way, the entire tab will be strong in all 3 dimensions from the point it bolts to the frame all the way to the D ring.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 24th, 2011, 01:21 AM   #6
ultimatehellhound
Once the bolts on the end are utilized it won't be going anywhere. This isn't my first rodeo.
I'll bet I can pick up the entire back end of the truck with one clevis and nothing will be moving anywhere. Who wants to put some cash on it?
Old May 24th, 2011, 11:10 AM   #7
littletrucker
I'd hit that
Picking it up or pulling it is different than relying on it to get you out of who knows where when you are stuck.
I'm not saying that the bumper is weak the frame might not hold up, I would use the 2 side bolts and the one on the bottom of the frame that the hitch is going on.
Id also would have tucked it up under the tailgate a little better and had it a little shorter so the end would tuck between the rear bed fenders
I was just trying to be nice and tell you what I thought about the bumper- I wouldn't pay 299 for a 2x6 with the ends capped off with some simple mounting brackets and d rings/mounts
Old May 24th, 2011, 11:13 AM   #8
Jeep ZJ
Jeep ZJ's Avatar
Looks nice but pretty plain for 299.
x2
Old May 24th, 2011, 11:44 AM   #9
ultimatehellhound
Care to take a guess on how thick the hitches mounting flanges on your tow rig are? The strength is in the design and pulling it at a 45 degree angle wouldn't budge it. Ever hear of the superstructure of a bridge? I prefer keeping things simple instead of some god awfull cluster of plate that looks out of place on anything but a spaceship or mallcrawler. If you are looking for a useless cluster of plate then please don't call me as I only build things that get used.
Old May 24th, 2011, 12:25 PM   #10
Bones
Bones's Avatar
I'll bet I could bend it. Picking up the truck is basically no weight at all compared to pulling on the bumper at a 45 degree (or more) pull during a recovery situation. You are puitting the plate in a perfect shear mode at the end of the frame. Think of how they bend metal in a press, you have the same set-up at the end of the frame. Move your gussets to the outside of the mounting tabs so they go all the way from the bumper to where the bolts go through the frame.
Trailer hitches are tube, or atleast angle iron where they mount to the frame. You are using flat stock steel. Competely different.
A bridge is designed to have a load on only one angle
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 24th, 2011, 01:05 PM   #11
ultimatehellhound
Tell you what, put up some cash and I'll hook the loader up and prove that it won't go anywhere. I'm fully aware of how a press works since I fab steel for a living. The 45 degree pull you are speaking of is exactly the same as a bridge.
Old May 24th, 2011, 01:08 PM   #12
littletrucker
I'd hit that
I couldnt take it anymore, I just pulled the rear bumper and hitch off my jeep- Gonna make a new one just to show you that its possible to have solid frame mounting without a cluster of plate
My trailer hitch has better mounting than your bumper- mounts to the side and bottom of the frame- Probably so it can resists side to side and up/down pulling better. but the people who make trailer hitches probably dont know anything, you should write them and tell them they are over killing the mounting and a loader couldn't pull off half of the mounting they have
Old May 24th, 2011, 01:13 PM   #13
You are one tough dude for sure. Please enlighten us, what kind of fab work do you do for a living? By the way, just guessing here but I don't think you fab steel for a living. You may however, fab things out of steel. I've been a supplier to the steel industry for years and I've yet to see a steel fabber anywhere.
Old May 24th, 2011, 01:16 PM   #14
ultimatehellhound
I guess since my post count isn't very high I can't know anything. I'm not 16 and this isn't even close to the first vehicle I've messed with. If you don't like it, don't buy it.
Old May 24th, 2011, 01:18 PM   #15
ultimatehellhound
I build compactors for Waste Management. My offer still stands, $500 bucks if you can yank it off with YOUR truck or Jeep. The only catch is I get to try and yank yours off with my truck.
Old May 24th, 2011, 01:21 PM   #16
Yank it off versus bending or distorting it is a different thing.
Old May 24th, 2011, 01:23 PM   #17
ultimatehellhound
Also want to price out and post what the materials cost since your a supplier? I'm in South Elgin, IL and have cash in hand.
Old May 24th, 2011, 01:29 PM   #18
Is your clevis mount 2 pieces sandwich welded together?
Old May 24th, 2011, 01:31 PM   #19
ultimatehellhound
It was the prototype so yes.
Old May 24th, 2011, 01:32 PM   #20
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
F.Y.I Bones does not know anything about statics and dynamics. I am pretty sure he is talking out of his ass and knows nothing about engineering technology.
ultimatehellhound I think your bumper is more super-badder-assed than anything anyone on this site can build you should sell it for $399. $299 sounds like it's too good to be true! You go girl!!!!
Tags
stupid nigger, wtf?, your welds suck
Page generated in 0.35726 seconds with 83 queries
