wont go into 4 LO - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2011, 04:24 PM   #1
jroberts#77
Fuck there goes the trans
jroberts#77's Avatar
Default wont go into 4 LO
i have a 2000 gmc sierra and it has an electronic t-case. and it will shift into 4 Hi just the way it should. But when try to shift into 4 Lo the light will just keep blinking and wont switch over.
Any help would be nice
Jake
jroberts#77 is offline   Reply With Quote
Old April 27th, 2011, 08:00 AM   #2
RADRICK
RADRICK's Avatar
Vehicle has to be stopped(not moving), trans needs to be in neutral or park, then select 4lo, same process to take it out of 4lo.
Old April 29th, 2011, 09:31 AM   #3
Bleay
sick of jackstand wheelin
Bleay's Avatar
If you are stopped like the last guy said and its still not working, it may need an encoder motor.
Bleay is offline   Reply With Quote
Old April 30th, 2011, 12:19 AM   #4
jroberts#77
okay now i jut feel stupid lol. i went out and ttryed it and it worked. i just figured that if you can switch into 4HI when in Drive and not moving you should be able to shift into 4Lo.
Old May 1st, 2011, 08:22 AM   #5
RADRICK
RADRICK's Avatar
Don't feel bad. Ten years at a gm dealership I saw a lot of real "stupid" stuff.
What is worse than not getting in to 4low, is when someone drives in off the freeway with it stuck in 4 low. "I wondered why it was showin 4000 rpm and sounded like it was reving really high".
Old May 1st, 2011, 01:53 PM   #6
jroberts#77
hahah now thats a good one
Page generated in 0.16700 seconds with 41 queries
