Inviscid Motorsports Ultra 4 racecar (and trail rig), UPDATE Now with Chassis pics - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2011, 02:58 PM   #141
Bones
Bones's Avatar
Originally Posted by High Center Hancho View Post
take off the header wrap...I was thinking about wrapping the rzr's exhaust and came up with many articles on why not to use it...this one was the best I found
http://www.centuryperformance.com/ex...e-spg-138.html
From their website
•Header wraps are designed to keep the heat in the header to improve scavenging of the cylinders. Keeping the heat in the header allows the exhaust speed to remain high. (the right idea)awesome, I want to pass the heat out through the muffler
•There are no header manufacturers that I know of that will warranty their headers if any header wraps are installed on their products.my headers were $150 and I already had to cut them up. Don't care about warranty...
•In most cases the header wrap damages the headers beyond repair. (I will explain below)see above
•If you run a lean mixture, you "may" see a slim performance gain using header wraps. A rich mixture may show slim to absolutely NO gain in performance. NOT looking for a performance gain, only a reduction in heat loss through the exhaust.
•If you do not mind replacing your headers and header gaskets regularly, and you like that ugly look of a wrapped header, go ahead and use the heat wrap. I don't care about looks, and this vehicle doesn't see enough hours of use to blow out gaskets. Replacing the gaskets every year would be fine.
You do know where my radiator is right?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 12th, 2011, 03:15 PM   #142
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Do you already have driveshafts made up for this?
Old May 12th, 2011, 03:19 PM   #143
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Originally Posted by Bones View Post
From their website
yea...but that was one of a few articles I read about that stuff...you don't think getting them coated will help you, do you? Maybe I read too much into it but I didn't like what I read about the heat warping and thermal fiction
Old May 12th, 2011, 03:29 PM   #144
Bones
Bones's Avatar
No, do you want to make them????
I am sure a coating would help a ton, but this was fast, easy and cheap(ish)
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 12th, 2011, 03:32 PM   #145
Bones
Bones's Avatar
It is finally here, the universal SBF MAF engine harness from RJM Injection
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 12th, 2011, 03:58 PM   #146
s.hembree
s.hembree's Avatar
I used one of their harnesses on my twin turbo early Bronco. Nice stuff...
Old May 12th, 2011, 08:53 PM   #147
Bones
Bones's Avatar
I hate soldering, especially when it is the result of cutting up your brand new $500 harness because it doesn't fit with your intake manifold....
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 13th, 2011, 09:02 AM   #148
trailrail302
Im going FAST!!!
trailrail302's Avatar
From their website
I had header wrap on mine since day one, never had one problem. Only down side is it will rust your exhaust out faster because it holds the moisture and the water but like Bill said we dont use them enough for it to matter. Thats my oppinion. And they cut down on cabin heat big time.
trailrail302 is offline   Reply With Quote
Old May 13th, 2011, 02:59 PM   #149
Bones
Bones's Avatar
harness laid out on the motor. Intake plumbed, rad lines plumbed, throttle cable installed. Need to add 1 vac line to the fuel reg.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 13th, 2011, 03:09 PM   #150
Cool parts peddler
Ironman Offroad's Avatar
Be running by Sunday night!
Old May 14th, 2011, 09:45 AM   #151
littletrucker
I'd hit that
littletrucker's Avatar
I ran header wrap on a set of headers in a Camaro.. It helped tremulously, kept alot of heat out of the engine bay, kept the floor alot cooler. This was just on a set of summit racing cheap headers.
Ive never ran a set of $1000+ coated headers but I'm sure that would be the way to go. I like the look of wrapped exhaust
Old May 15th, 2011, 08:27 PM   #152
Mr.Green
I can levitate!
Mr.Green's Avatar
Racing is stupid.
Old May 15th, 2011, 08:36 PM   #153
kj kyle
kj kyle's Avatar
are you worried about heat from the exhaust effecting the shock resivours?
kj kyle is offline   Reply With Quote
Old May 15th, 2011, 09:09 PM   #154
boggin-machine
boggin-machine's Avatar
dale you got this at your shop? looks awesome so far bill
Old May 17th, 2011, 12:06 AM   #155
Bones
Bones's Avatar
Not really. The resivours will get crazy hot as is. The exhaust really isn't as close as it looks.
It's at my place. Once it is complete it will be at Dale's on occasion.
I am a few pictures behind, so here goes.
The front shafts are here and look awesome.
Willwood brakes. In the background you can see the front firewall.
I started the wiring. It sounds goofy, but I tacked staples onto the chassis to run the wires through. it helps keep them all in line and on top of the tube.
And a sneak peak at the gauges. The switch panel looks pretty clean, but no pictures of that until it is complete
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 17th, 2011, 12:10 AM   #156
Christmas Cookie
looks good bill...I get a deal on Brembo stuff so if you need anything from them PM what you want and I'll get you a price
Old May 17th, 2011, 08:09 AM   #157
kickstand
circling the drain
kickstand's Avatar
Are you gonna put any wire loom on the wires?
Old May 17th, 2011, 10:41 AM   #158
Bones
Bones's Avatar
No, makes it harder to chase down a problem in a race
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 17th, 2011, 10:44 AM   #159
kickstand
circling the drain
kickstand's Avatar
makes sense.
Old May 17th, 2011, 10:45 AM   #160
Bones
Bones's Avatar
makes sense.
I should clarify. Anything in the engine bay has loom to help protect it from rubbing and heat. Anything on the chassis is open.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.57147 seconds with 84 queries
