Good engine builder/machine shop - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2011, 11:05 PM   #1
nkubicz
nkubicz's Avatar
Default Good engine builder/machine shop
I need a good/great engine builder/machine shop that has a good turn around time.. The 4.0 jeep motor has finally had it.. SE MI thnxx
nkubicz is offline   Reply With Quote
Old April 24th, 2011, 07:01 AM   #2
kickstand
circling the drain
kickstand's Avatar
Fenton Machine shop sucks, don't go there.
Old April 24th, 2011, 07:20 AM   #3
Disturban
Disturban's Avatar
Pierce Race Engines in Lansing built the motor in my Trans Am and did a fantastic job at a reasonable price and time...I highly recommend them!
Old April 24th, 2011, 08:10 AM   #4
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
x2
There's a shop on the corner of N. Holly Rd. and Evans Rd in Holly. I've had good luck with. I'ts ran out of a few pole barns, but those guys have helped me out a bunch and do good work.
(810)241-8050
This is where it's at, I've lost their card so I don't know the actual adress.
http://maps.google.com/maps?q=42.864...2&z=18&iwloc=A
If you hit the satellite view it's the house with all the vehicles and equipment in the driveway.
Old April 24th, 2011, 08:36 AM   #5
Disturban
Disturban's Avatar
You mean Kodiak450r's house
Old April 24th, 2011, 08:45 AM   #6
Captain Ledd
Ranger Addiction?
Oh hell he's on here? Well even better.
Old April 24th, 2011, 09:55 AM   #7
shawn
Resident HVAC/R Jambi
shawn's Avatar
Mid 5 Auto has a pretty good machine shop in Livonia. Then there is also Chucks Engine in Plymouth, I'm sure he's still doing work. And another place in Ann Arbor I just used to bore out some Outboard Motor Cylinders.
Old April 24th, 2011, 10:13 AM   #8
AFRd_CJ5
AFRd_CJ5's Avatar
Engine Machine Services in Potterville
The guy that used to do all the engine assembly from Pierce Race Engines is now there. He does awesome work.
AFRd_CJ5 is offline   Reply With Quote
Old April 25th, 2011, 04:11 PM   #9
nkubicz
nkubicz's Avatar
Well looks like after a few calls, chuck's engine in plymouth is right on the money with things.. Friendly service, and a great turnaround time.. I'll post my final thoughts once the rebuild is in and running..
Old April 25th, 2011, 04:30 PM   #10
shawn
shawn's Avatar
He's great, very knowledgeable, and reasonable. I've had all my cranks turned by him.
Old May 15th, 2011, 03:46 PM   #11
nkubicz
nkubicz's Avatar
The Motor was dropped off and back in 10 days, painted, bagged and rdy to go... Good service at chuck's... We ended up not doing a stroker, just mild porting and a cam and using the older style piston's that dont have skirt problems...
Getting a camshaft that utilizes the stock springs was a task, we actually had to call comp cams and get a camshaft made.. There are a limited number of fuel injected camshafts that are out there, all of which require aftermarket springs for the lift numbers.. Problem is they don't make aftermarket springs anymore for the newer 4.0 heads... Unless you wanna spend some cash on some pretty intense maching of the head for a ls1 spring to fit.. So here's the specs for the biggest FI Cam you can use with NEW Stock springs..
435/448 lift
lobe seperation 113
206/212 duration at .050
Page generated in 0.29510 seconds with 56 queries
