Parking brake noise? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 22nd, 2011, 12:23 PM   #1
Disturban
Disturban's Avatar
Default Parking brake noise?
Ever have the parking brake on the inside of the rear rotor make noise? This truck has disc brakes on the rear and the pads are at least 1/2 left but when I make a slight left turn in a parking lot while going slow I can hear metal on metal sound...it has a hollow sound just like bad drum brakes. The parking brake is in fact a drum brake so I am thinking maybe some hardware broke inside or something?
Another thing is when I apply the parking brake and then release it the pedal stays right where it was at, I have to manually pull it up? Anyone ever experience anything like this? I don't think it is an axle bearing that would be more of a grinding sound and this is more of a scraping sound.
Pretty shitty day so I don't think I will be pulling everything apart today...was just wondering if this kind of noise is ever caused by the parking brake or if this is a common problem?
Old April 22nd, 2011, 12:53 PM   #2
Bishop
Bishop's Avatar
Cables are probably rusted up.
Old April 22nd, 2011, 01:01 PM   #3
Disturban
Disturban's Avatar
Would that cause a metal on metal scraping noise though? I am thinking maybe broken hardware or the ebrake might have been pressed in slightly and the material on the shoe is down to metal? When I jumped in it this morning the pedal was not up as high as when I pressed it down and then pulled it back up.
I guess I will find out tomorrow and take it all apart.
Old April 22nd, 2011, 01:28 PM   #4
firehawk
Live Action!
firehawk's Avatar
Possibly a bad bearing allowing it to cock to the side a touch and rub?
Old April 22nd, 2011, 01:33 PM   #5
Disturban
Disturban's Avatar
Ooooooo I was not trying to hear bad bearing...lol
But I guess it is a possibility.
Old April 22nd, 2011, 08:27 PM   #6
Disturban
Disturban's Avatar
I just took it all apart and my back pads are almost gone, there was a bunch of dried up mud in everything and the dust shield is rusted so bad it is out of shape, so I think one of those issues if not all of them is causing the noise.
However I have a little play in the axle it's self, maybe 1/32nd up and down how much tolerance is allowed for the axle bearing...is it time to change it? I can also move my axle in and out with a good 1/4 play, is this normal or is the c clip or slot on the axle for the c clip getting worn out and need to be replaced?
This is on a 10bolt rear end, forgot to mention that.
Page generated in 0.29736 seconds with 41 queries
