Dana 44 steering knuckle swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2011, 01:30 PM   #1
jerrysf
jerrysf's Avatar
Default Dana 44 steering knuckle swap
Im looking to see if it is possible to swap steering knuckles from a chevy dana 44 on to a ford dana 44 axle to clear a set of rims i purchased...the rims came off of a chevy 3/4 ton with a dana 44 and they fit on there perfect but they wont clear my calipers on the ford dana 44 axle and i would rather not get spacers unless i have to so if anyone can answer this question for me or if anyone has done it and could give a few tips on the swap that would be great...thanks
jerrysf is offline   Reply With Quote
Old April 21st, 2011, 10:23 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Yes is will work - providing that you use the Chevy components from the knuckle out including the stub shaft. The chevy spindle is a 6 lug at the knuckle where the Fords were all 5 bolt.
Old May 12th, 2011, 10:24 PM   #3
dirtrider
Dopey
dirtrider's Avatar
does this also mean that you can go the other way, use a chevy knuckle and then running a ford spindle bearings, brakes ect. I am looking to run a for 9" rear, 5 x 5.5 bp and then run a chevy front 44 and need to get it to 5 x 5.5 bp.
dirtrider is offline   Reply With Quote
Old May 12th, 2011, 10:27 PM   #4
insaneoffroader
insaneoffroader's Avatar
No. You have to use the ford knuckle with the ford spindle. The knuckle to spindle bolt pattern on a chevy is 6 bolt; ford knuckle to spindle is 5 bolt.
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old May 13th, 2011, 06:41 AM   #5
dirtrider
Dopey
dirtrider's Avatar
got ya! but the ford knuckle will match up to the chevy C?
Old May 13th, 2011, 06:51 AM   #6
insaneoffroader
Definately should. A dana 44 is a dana 44.
Page generated in 0.17321 seconds with 41 queries
