Passenger or driver side drop? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2011, 11:34 AM   #1
BigBlue92
Default Passenger or driver side drop?
I've been reading up on solid axle swaps and Dana 44s and I keep seeing that some are driver side drop and others are passenger side drop. What does this mean and whats the difference between the two?
BigBlue92 is offline   Reply With Quote
Old April 21st, 2011, 11:51 AM   #2
joescamaro67
joescamaro67's Avatar
this means you probly shouldnt attempt the swap.
joescamaro67 is offline   Reply With Quote
Old April 21st, 2011, 12:13 PM   #3
powerranger33
powerranger33's Avatar
x2
powerranger33 is offline   Reply With Quote
Old April 21st, 2011, 09:21 PM   #4
BigBlue92
wow thanks for the help. just tryin to learn
Old April 22nd, 2011, 11:54 AM   #5
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
They are referring to which side of the truck the differential (center section of the axle) is on. A driver side drop would have the diff on the drivers side. There is also high pinion and low pinion, meaning the part that bolts to the drive shaft is either on top of the diff (HP) or on the bottom (LP). A lot of Ford fronts are high pinion making them more desirable for swaps because of pinion ground clearance and reduced drive shaft angles.
Page generated in 0.26687 seconds with 38 queries
