transfer case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2011, 10:18 AM   #1
mudchucker
mudchucker's Avatar
Default transfer case
Does anyone know if any other transfer case will fit behind a c4, other than the dana 20? I know an atlas will, but i am looking for something a little more common and a helluva lot cheaper.
thanks,
mudchucker is offline   Reply With Quote
Old April 22nd, 2011, 08:01 PM   #2
sjhenderson18
MEMBER
sjhenderson18's Avatar
yes as long as it has the correct output shaft and tail housing. NP205,203,208 and quite a few others from just about any ford truck will interchange, just about but they use a different bolt pattern then the dana's i think.
sjhenderson18 is offline   Reply With Quote
Old April 22nd, 2011, 08:28 PM   #3
bigblockford79
Big Block Ranger
bigblockford79's Avatar
The C4 uses the smaller bolt pattern, so the full size t-cases just will not work. Look for a t-case from any year Ranger(not Expo), any of those will work and you can chose electric or manual shifted versions.
Here is a list of adapters from Advance if you want to get really pricey.
http://www.advanceadapters.com/categ.../0/0/0/0/95/0/
Old April 23rd, 2011, 07:11 AM   #4
mudchucker
mudchucker's Avatar
thanks guys!!!
Page generated in 0.20183 seconds with 35 queries
