gear ratio close enuff ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 20th, 2011, 11:54 PM   #1
A4X4SPIT
A4X4SPIT's Avatar
Default gear ratio close enuff ?
Im thinking about doing a solid axle swap in a 99 tracker I have... the gear ratio in the tracker is 462:1 & the ft axle I have to swap in has 456:1 are these gears close enuff ?
A4X4SPIT is offline   Reply With Quote
Old April 20th, 2011, 11:59 PM   #2
boggin-machine
boggin-machine's Avatar
no
Old April 21st, 2011, 12:09 AM   #3
I suck cocks. Lots of them.
locally famous
i say yes. my truck had a 3.42 front and 4.10 rear. it wasnt far enough off to rip up wet grass when locked in. that little difference you have could be made-up with air pressure.
Old April 21st, 2011, 12:36 AM   #4
A4X4SPIT
A4X4SPIT's Avatar
I was thinking along those lines
Old April 21st, 2011, 01:01 AM   #5
groundhog
groundhog's Avatar
Just do it!!!!!!
groundhog is offline   Reply With Quote
Old April 21st, 2011, 01:58 AM   #6
Toivo
Feel lucky?
Toivo's Avatar
gruoundhog good to see you here man!
also, yes to the OP's original question
Old April 21st, 2011, 06:36 AM   #7
1% difference.......... no big deal. Just don't drive it locked in on pavement.
Old April 21st, 2011, 09:07 AM   #8
yyj87
yyj87's Avatar
yyj87 is offline   Reply With Quote
Old April 21st, 2011, 09:37 AM   #9
skife
skife's Avatar
i'm running 3.55 front and 3.73 rear and everything is fine so far, i Only use 4x4 offroad.
Old April 21st, 2011, 09:40 AM   #10
Silver93XJ
Silver93XJ's Avatar
your only runnin it in the dirt! No biggie!
Silver93XJ is offline   Reply With Quote
Old April 21st, 2011, 10:02 AM   #11
A4X4SPIT
A4X4SPIT's Avatar
ya it would only get the hubs locked off road Im just going to take my pos daily driver and gather up what it needs to make a solid axle dirt toy i would expect if its got the hubs unlocked it wouldnt matter what gears it has
Old April 21st, 2011, 10:04 AM   #12
kickstand
circling the drain
kickstand's Avatar
agree, if using offroad only it'll be fine.
Old April 21st, 2011, 10:18 AM   #13
masterbeatty
masterbeatty's Avatar
I ran a 355 and a 373 together for a while and didnt have a bit of problems, i did try to avoid dry pavement though
Old April 22nd, 2011, 07:37 AM   #14
curt1656
Praise the lowered
curt1656's Avatar
Yes.
Page generated in 0.23343 seconds with 65 queries
