what trans fluid for auto behind 7.3? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 20th, 2011, 11:52 AM   #1
kickstand
circling the drain
kickstand's Avatar
Default what trans fluid for auto behind 7.3?
standard issue stuff or is there a consensus on a good fluid to run? Tranny has under 100k on it and I want to swap the filter and top it off.
Old April 20th, 2011, 12:08 PM   #2
Bones
Bones's Avatar
are you looking to spend a lot of money?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 20th, 2011, 12:25 PM   #3
michigan maniac
michigan maniac's Avatar
ive been told by trans guys that as long as its red your good!! also heard of a guy who put exspensive fluid in his trans, it turned clear, he drained it put wall mart fluid in and trans has lasted years... ive got a 55 gallon drum of penzoil atf multi-fit at work, i run it and never have any issues,
Old April 20th, 2011, 02:43 PM   #4
kickstand
circling the drain
kickstand's Avatar
I am not looking to replace my transmission, I am looking to maintain it. I barely put any miles on the truck, so it's not like I am going to be changing it every week, in other words, I'll spend a few extra bucks if there is a better fluid reccomendation than the standard shit.
Old April 22nd, 2011, 08:59 PM   #5
sjhenderson18
MEMBER
sjhenderson18's Avatar
What year, some run mercon v and superdutys run atf 4 i think. You dont need to spend a lot of money, it takes quite a bit of fluid anyway from what I remember.
sjhenderson18 is offline   Reply With Quote
Old April 25th, 2011, 03:30 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
1996 and newer Ford's took Mercon V, we up until the late 2000's at least
Old April 25th, 2011, 03:45 PM   #7
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
I would recommend spending the extra $75 and go with royal purple. You can order it online through advanced auto with there coupons for about 9.50 a bottle.
If you end up going the standard route advance has coastal for 2.99/qt.
Silver Bullet is offline   Reply With Quote
Old April 25th, 2011, 03:53 PM   #8
Bones
Bones's Avatar
I would run motorcraft. Buy it in bulk at Walmart (eventhough I hate that place), they have good prices on motorcraft oils and filters.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old April 26th, 2011, 10:31 AM   #9
Quiefinator
go'til itsounds expensive
Just make sure it is Merc V, no dexron.
IIRC Merc V was updated in 2006 to service your transmission. If you look in your owners manual and it says NOT to use Merc V, do some research first.
http://www.fcsdchemicalsandlubricant...ickref/atf.pdf
Page generated in 0.21044 seconds with 50 queries
