Dana 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2005, 10:10 AM   #1
Cube
Captain of my pants
Cube's Avatar
Default Dana 20
So my TC is finally starting to puke on me. I liked my dana 20 I was thinking of havnig it rebuilt maybe with a lower low gear. Or I was thinking maybe put a chevy TC behind my turbo 350 and sell my adator. so what do you guys think the pros and cons would be?
Cube is offline   Reply With Quote
Old November 6th, 2005, 10:37 AM   #2
Chop
Mischievous Badger
Chop's Avatar
get the dana 20
Old November 6th, 2005, 11:39 AM   #3
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Let's look at your GM t-case options:
NP205: Heavy as hell, 1.96:1 low
NP203: Not as heavy as 2.5, 2.00 low
NP208: 2.61:1 low, chain driven, heavy duty
NP241: 2.72:1 low, chain driven, heavy duty
Any of those t-cases will require driveshaft, crossmember, trans tunnel modifications, and possibly exhaust modifications. You could find a 1980 Scout D300 which would be a swap which would require no other modifications and give you a 2.62:1 low range. But, finding one from an automatic would still set you back a few hundred and you wouldn't have a rebuilt case.
Personally, I'd rebuild the D20 with a set of Tera-low gears (3.15:1 low range for D20).
Contact DC4WD 540-473-1096 http://www.DC4WD.com for the lowest price around. It'll be an in/out job with no other modifications. If you want to burn more cash, upgrade the output to 32spline ($350+) and install some twinsticks and get rid of that crappy brass bushing factory shifter linkage.
Old November 6th, 2005, 02:11 PM   #4
PavementPounder
PavementPounder's Avatar
Consider the lower D20 gearing with the rebuild. Perhaps a budget gear swap using a D18.
Old November 6th, 2005, 03:08 PM   #5
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I would keep the D20, but do the low gear swap mentioned about. I know someone with that setup in their CJ7 w/V-8 D44's 38"s, spooled, ARB, etc..hasn't had a problem with the strength of the D20. And going to the 3.15:1 was a huge improvement, over the stock 2:1.
Old November 6th, 2005, 03:13 PM   #6
Chop
Mischievous Badger
Chop's Avatar
can a D20 be fliped?? nice site cornfed
Old November 6th, 2005, 03:26 PM   #7
Cube
Captain of my pants
Cube's Avatar
ok the lower gear set is like 700 or 600 bones, hmmmmm
Old November 6th, 2005, 04:21 PM   #8
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
My buddy bought his on ebay or Pirate....new in the box for around $400. Try lookin' around for a while before buying new.
Old November 6th, 2005, 07:34 PM   #9
Cube
Captain of my pants
Cube's Avatar
dam I will have to keep and eye out for that
Old November 7th, 2005, 07:53 AM   #10
Overall, whats your drivetrain setup?
Motor, trans(TH350?) axle gears, and tire size?
For maybe $200, you coudl probably get all the parts to put in a Dana 18 low range to get to 2.46:1, don't know if thats the range you want. I've seen people have good luck with NP208s as well.
Old November 7th, 2005, 08:01 AM   #11
cornfed
cornfed's Avatar
Here's the only clocking ring I know about for the D20. Bulltear Link
Old November 7th, 2005, 12:34 PM   #12
Chop
Mischievous Badger
Chop's Avatar
thank bud eather a d300 or a d20 will be in my future not sure if im going to flip or run a diffrent front axle i have a 9 inch for the rear and a T18 trans. still planing and getting ideas. but thank for the info
Old November 7th, 2005, 04:59 PM   #13
Cube
Captain of my pants
Cube's Avatar
I have a 350, turbo 350, and running 35 inch tires with 4.88 gears
Old November 7th, 2005, 05:06 PM   #14
shawn
Resident HVAC/R Jambi
shawn's Avatar
I'd keep the 20 and get better gears for it, but what exactly is wrong with your current one? I rarely hear of any problems with a 20 or 300. If you are going ot get a different t/c and adapter it would probably cost more than just putting the $$ forth for the gears.
Old November 7th, 2005, 05:16 PM   #15
Cube
Captain of my pants
Cube's Avatar
yea its just old, just getting real real hard to get into gear now and leaking like crazy, yea I just had the linkage rebuild and new yoke so I am thinking of doing a total rebuild on it, I wish I could find cheaper gears, I mean the TC is almost 30 years old you know
Old November 7th, 2005, 05:26 PM   #16
With that setup, I'd think running a 2.46:1 low range would be ideal for all around michigan wheeling..
3.15:1 is going to end up being pretty low for 1st gear and reverse in low range.
Need a Dana 18 T-case and a gear from a Bronco Dana 20.. I think Jeff's bronco graveyard sells the gears..
Old November 9th, 2005, 09:16 PM   #17
Muttly
Muttly's Avatar
I'm running the d-18/bronco gears in a dana 20. 4.88's locked t-18 35-15.50 swampers and an amc 360.... I've busted the rear output and chucked a few driveshafts, but the old 20 is still strong. I looked at the 3.15 low gears, but that's alot of $ to go from 2.46 to 3.15. (plus the granny gear in the tranny helps alot) Dana 20's are everywhere and dirt cheap, plus if you go chevy t-case you loose alot of rear driveshaft.
Muttly is offline   Reply With Quote
Page generated in 0.32616 seconds with 74 queries
