Advice on what I should use to hang up a picture on the wall - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > The recycle bin.
The recycle bin. Posts deemed annoying. If you see your post here, take a hint.
Old April 18th, 2011, 12:32 PM   #1
howell_jeep
Last Free Man
howell_jeep's Avatar
Default Advice on what I should use to hang up a picture on the wall
It's a standard wall construction and I need to hang a picture frame. I will be using a standard picture hanger that you nail into the drywall. My question is what type of hammer I should use? What is recommended?
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Old April 18th, 2011, 12:35 PM   #2
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Brick hammer or cresent hammer and if those dont work then c4
I'm the man in White.
Old April 18th, 2011, 12:36 PM   #3
SizeMatters
Sketchy, Son....
SizeMatters's Avatar
Can never go wrong with a splitting mull
SizeMatters is offline   Reply With Quote
Old April 18th, 2011, 12:38 PM   #4
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
30 LB sledge works pretty good too. Especially on the drywall!
Old April 18th, 2011, 12:39 PM   #5
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
SlayerXJ is offline   Reply With Quote
Old April 18th, 2011, 12:42 PM   #6
TopGunn
Burried
TopGunn's Avatar
Send a message via AIM to TopGunn Send a message via MSN to TopGunn
Old school it and use a rock! One from the yard not the little baggie!
TopGunn is offline   Reply With Quote
Old April 18th, 2011, 12:45 PM   #7
motorcity
OlllllO
motorcity's Avatar
last picture i hung i used a jack hammer, was hard to hold but after a half hour or so i got it, looks pretty good, a little sideways.
motorcity is offline   Reply With Quote
Old April 18th, 2011, 01:14 PM   #8
chevyk10
FORD / GM
chevyk10's Avatar
chevyk10 is offline   Reply With Quote
Old April 18th, 2011, 03:32 PM   #9
dentedvw
╭∩╮ 0_o
dentedvw's Avatar
The answer is obviously to use a standard one, as everything else is standard. You would use a metric one if you had bought your drywall at Home Depot, but that's not the case, is it. No, it's not.
www.thereifixedit.com
dentedvw is offline   Reply With Quote
Old April 18th, 2011, 04:03 PM   #10
kerryann
German cars are hot
kerryann's Avatar
I usually make one of my slaves or my husband do it..
problem solved.
kerryann is offline   Reply With Quote
Old April 18th, 2011, 04:07 PM   #11
aber61
aber61's Avatar
3m has a product that will stick and NOT damage paint or drywall as for install pls contact one of kerryann's slaves
aber61 is offline   Reply With Quote
Old April 18th, 2011, 04:13 PM   #12
SizeMatters
Sketchy, Son....
This made it too the bin rather quickly....
Page generated in 0.47718 seconds with 58 queries
