Axels: Rubi Dana 44 F & R 5:13, Alloy Shafts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 16th, 2011, 02:20 PM   #1
Melmo
Melmo's Avatar
Default Axels: Rubi Dana 44 F & R 5:13, Alloy Shafts
SOLD
Rubi Dana 44 F & R Axles, 5:13 Alloy Gears, Alloy Shafts, Alloy tube seals on front. Includes Rubicon locker pumps, locker switch etc. Located at zip code 53185
Rear is setup for coilovers a triangulated upper and is trussed. Front is setup for coilovers, and 3 link with panhard. Modifying back to OEM brakets is no problem if need be.
Front axle is fitted with the WJ lower ball joint as I had upgraded to WJ front brakes, however the WJ outer knuckles and brakes are not included. I will include the stock Rubi outers with the axles if you wish, but the lower ball joints will need to be changed back to the stock Rubi type. No big deal, push out the WJ and push in the TJ.
Upgraded rig to 40's and Pro Rocks. These axles held up to the 37 x 13.50 x 17 Nitto Mud Grapplers, all over Colorado and Moab for 3 seasons without ever breaking a shaft . Didn't want to push them with 40's however.
Asking $3,300 OBO for the entire axle package as described above.
The Nitto Tires are also for sale in this thread Asking $1,100 OBO
37" Nitto Tires
PM with questions or offers
Mike
Melmo is offline   Reply With Quote
Old April 17th, 2011, 08:40 PM   #2
Melmo
Melmo's Avatar
Btt
Old April 17th, 2011, 08:50 PM   #3
SizeMatters
Sketchy, Son....
SizeMatters's Avatar
I saw $1100 and got excited....then I realized it was just for the tires
Glws!
SizeMatters is offline   Reply With Quote
Old April 18th, 2011, 10:48 PM   #4
Melmo
Melmo's Avatar
Well make an offer and maybe you can still be excited
Old April 21st, 2011, 12:29 AM   #5
Melmo
Melmo's Avatar
Btt
Old April 21st, 2011, 05:35 PM   #6
Melmo
Melmo's Avatar
Btt
Old April 21st, 2011, 10:09 PM   #7
ted99xj
Hi, I am looking for something bolt in for my TJ Would it be possible for you to convert these to the factory mounts?
Ted
ted99xj is offline   Reply With Quote
Old April 25th, 2011, 07:53 PM   #8
Melmo
Melmo's Avatar
I suppose it is possible. Let me know if your are seriously interested and I will look into it
Old April 26th, 2011, 09:55 PM   #9
ted99xj
I am very interested if it isn't too much trouble. I only ask because in your post "Modifying back to OEM brakets is no problem if need be."
I have absolutely no fabrication skills and would have no idea on how to get your current configuration to work for me. I am in need of a front axle after an accident so I thought why not upgrade.
Ted
Old April 27th, 2011, 11:51 PM   #10
Melmo
Melmo's Avatar
I am looking into the stock brackets now but another good option would be for you to look at a full traction ultimate lift kit. That would give you a tringulated rear upper and you would only need the spring buckets and shock mounts then. The front is not an issue anyway as the three remaing brackets are oem now anyway.
Also if you already have axles with stock brackets on them it would be pretty darn easy to cut them off and move them to these axles.
Also I was assuming you had a TJ but then I saw your signature and though it might be an XJ which would make it even easier to do.
Old April 29th, 2011, 08:04 PM   #11
Melmo
Melmo's Avatar
Btt
Old May 4th, 2011, 08:37 PM   #12
Melmo
Melmo's Avatar
btt
Old May 13th, 2011, 10:37 PM   #13
Melmo
Melmo's Avatar
I may be making a trip to superlift park for memorial day so I could save you some money on shipping for these. Make an offer
Old May 14th, 2011, 12:58 PM   #14
Melmo
Melmo's Avatar
Bump
Old May 17th, 2011, 08:14 PM   #15
Melmo
Melmo's Avatar
Ttt
Old May 17th, 2011, 11:06 PM   #16
2fst4you
2fst4you's Avatar
Willing to seperate?
Old May 18th, 2011, 09:10 PM   #17
Melmo
Melmo's Avatar
Maybe what are you looking for?
Old May 21st, 2011, 02:35 AM   #18
Melmo
Melmo's Avatar
btt
Old May 23rd, 2011, 11:11 PM   #19
Melmo
Melmo's Avatar
Ttt
Old May 30th, 2011, 05:10 PM   #20
Melmo
Melmo's Avatar
Ttt
Tags
dana 44, front axle, gears, locker, rear axle
Page generated in 0.41608 seconds with 84 queries
